Maximat 7 Lathe
Help Support HMEM:
Gerald Pierce
Fairview, NC USA
I purchased my Maximat 7 new about 50 years ago. I only had to make two repairs. I replace one selector shift fork lever. I also had to replace the lead screw nut. The adjusting screw tab on the nut broke. Could not find a replacement. I made a replacement nut from bronze on the lathe. This is a left hand 5/16 x 20 thread. A challenge but interesting part to make.
Gerald Pierce
SmithDoor
Clovis Ca
Looks like great lathe
The only way today to get good is buy old ones and fix.
They just do build that good any more.
goldstar31
Twixt Tyne and Tees
Might I disagree! I have a Myford Super 7 with gear box and powered cross feed which NEW i.e. have been £3000( basic) which without ANY tooling whatsoever, will set people back a very cool £8 000 or perhaps 10 grand:rolleyes:. Yes, I have one and a fitful of accessories both bought or made. A rather ethereal sum and I am certainly not alone in getting one. Writing as a former accountant, it is a sound investment and one which I have briefed my two holders of. Enduring Powers of Attorney and my future executers and beneficiaries- NOT to be sniffed at;)
From the practical and considerably cheaper Chinese Sieg C4 with variable speed motor and power cross feed and iron gears not plastic things from Deutschland, Deutschland Uber alles, made out of plastic. I do have preferences!
Emco made lathes, if I recall, for the use of slave labour in Dachau Concentration Camp.
Not quite what one expects but true nevertheless.:(
So back to the Sieg, it is incredibly cheap- and refreshingly accurate. I've got one.
None of this dreary poor little boy peering through the steamy Christmas offerings- and wishing to be able to go in. Apparently there is more about than it would seem at first glance.
My experiences on such things- of course.
tornitore45
HMEM Lifetime Supporter
I have a Sieg 9x20 and paid $1,000 with tax and shipment. A ridiculous low price. Accuracy is more an operator factor than a machine characteristic.
I made several modification to improve practicality but no amount of improvement can overcame a bad design. The Sieg design (Actually a copy of the Austrian Enco) is sound, and a solid performer for a 1000 bucks.
Miraculously, the machine has been turning out better and better part with less scrap since I got it as my first lathe. I wonder why...
goldstar31
Twixt Tyne and Tees
I had a 9200 which was one with a Myford 'nose' to accept my tooling.
At the price, it was a bargain but the lowest speed was 130 RPM which was too fast for my reactions. a funny way to operate the motor and a poor travel for the tailstock 'poppet'. I changed the motor to 3 phase. As has been said, a good solid machine for the price.
SmithDoor
Clovis Ca
My choice of good all around lathe is 9N A South Bend Lathes.
My lathe has quick change gear box, Tapper attachment.
I have used South Bend Lathes for over 50 years.
For hobby lobby it is very flexible and has lots of tooling.
All iron/steel gears and back gear.
Made in the USA too.
tornitore45
Same here. One of the best upgrades I did was to replace the motor wit a 3 Phase 1HP plus VFD 90% of the time I work on one of the pulley sheave.
Occasionally I need to move the belt for extreme RPM conditions.
SmithDoor
Clovis Ca
I did that lathes using DC motors
The DC motor speed range 60 to 1. The down side to DC is the cost
But speed control was great 60 RPM to1800 RPM.
Steamchick
Sunderland , UK
DC will - in theory - give better motor control and higher torque at low motor speed (max torque at zero rpm). But the digital motor controls on AC motors are now used for traction - electric cars, trains, etc. - because of the feedback of the back-EMF to the electronics giving more precise control for creeping from rest.... As far as I understand , anyway. (I worked at Nissan on LEAF, but not on motor control, so only picked up "rumours"). Maybe on the lathe you don't need to "creep-from-rest"? I do that in the mornings to drag myself from bed, but when thread cutting with tap or die on the lathe I do it "by hand".
SmithDoor
Clovis Ca
My self a good variable belt drive is best. But takes more work to install.
They are now using in cars.
Steamchick
Sunderland , UK
First used in cars in mass production in the 1960s with rubber belts, and since the 1980s with steel belts (Nissan CVT). Very efficient compared to geared automatics.... But there is a variable speed lathe at my local Model Engineering club, dating from 1960s or 60s? I need training before I am allowed to use it. I think it uses opposing cones.., but I don't know if belt or moving-idler to make the transfer of torque?
BaronJ
Grumpy Old Git.
York, North Yorkshire
Hi Guys,
Just in case no one has noticed, more and more motors are moving to three phase and electronic variable speed drive systems ! Also many motors that used brushes and commutators to supply power to rotating parts are now becoming brushless and don't actually have any electrical contact with any moving part of the machine. Also being able to be easily speed controlled.
Some may have noticed a trend here. Lack of copper ! Many new motors are starting to use aluminum wire for the winding, particularly BLDC (Brush Less DC) ones.
Also notice that this trend is towards reducing costs and increasing profit !
goldstar31
Twixt Tyne and Tees
In the days of Yore- those Good old Days, the average model maker's lathe was powered on line shafting- with a scrapped 1/4HP electric motor. Importantly, it all worked and there was nobody to ask silly questions and to get silly answers. This was the late and much lamented Don L Ashton- who wasn't an engineer but knew more engineering as his books on valve gear are still being used. So there. Don also was a world authority on tugboats, repairing musical instruments and composing music- when he wasn't re-building a full size locomotive.
He would bore me rigid at 3AM and I would be lulled into sleep.
So the other one was the much accepted Kenneth C Hart writing as Martin Cleeve on his epic 'Screwcutting in the Lathe and who hadn't enough money to take out a Patent but drove half a Myford ML7 with line shafting and TWO motors- one a full horse power and the other a 1/3rd one. That was about 1953 if my memory serves me well.
He could cut metal on the lathe faster than his home made mechanical hacksaw.
So it has ALL been done- long before there was a glint in one's father's eye.
Mine, incidentally was brazing up carbide bits- with his Decontamination Suit, tin hat and service respirator on a nail in the blacksmith's shop.
As I said- it's All been done and repeated and repeated. Being an 'engineer'? Huh, I'made more things with a fountain pen. Enough o retire comfortably at 55- far too late in life really!
fcheslop
The land of the Prince Bishops
Electronic speed control on a small lathe with short duration may well be OK but I would be concerned about the motors cooling on a long job.
CVT thought DAF did that in the 60s or at least I remember a few swearing lessons changing the belts
Nothing new just reworked re badge re branded and ultimately recycled .
Never made enough from the fountain pen to retire early but became a thorn in big companies sides and they were glad to buy me out more than once
SmithDoor
Clovis Ca
First time I saw steel belts is equipment from 1950's
The variable belt transfer of torque.
Why did you need training on variable drive???
Gerald Pierce
Fairview, NC USA
"The Sieg design ( Actually a copy of the Austrian Enco)? My Maximat 7 was made in Austria by EMCO Maier Corporation. I paid $795 in 1970. With geared headstock, taper roller bearings, and vertical milling/drilling unit If you can get a copy today for $1,000 that is a ridiculous low price.
goldstar31
Twixt Tyne and Tees
I got a SIEG C4 in excellent condition for just £350 and added a vertical mill drill attachment( new)
No great thing. At the end of the day, it is only a thing to help pursue one of my hobbies.
On the other hand, my present Myford is an investment as well as a very practical piece of kit--- for which spares are still available.
Emcos, however they are presented, do not fall into this category and their price also reflects this.
OK, I've got a top of the range lathe - plus a vst collection of accessories- which - tongue in cheek- is not in the same league game.
Hint, I studied cost accountancy, taxation and whatever-- but not engineering- as is obvious. Myfords have 'je ne sais quoi' but - but I'm not alone in having this opinion.
Steamchick
Sunderland , UK
Hi SmithDoor, No real idea "why". but I was told that when the "new" (mechanical) variable speed lathe was fully commissioned, there would be training before anyone could use it. They do teach people with zero workshop experience to be passable modellers, so the context was a bit "global"... I haven't yet needed to borrow any of their lathes as my Cheap Chinese variable speed noggin (Chester DB7) does everything I need at a speed I am happy with. For tiddly stuff I use my old Unimat (Re-motored, because I over-worked it and the motor armature fried... Should have read all the instructions - e.g. "Stop for cooling after 10 mins of use"!). I want a bigger swing and more torque, but until I can knock through into next door and "borrow" their garage I just don't have the space for a bigger-bed lathe....
Gerald Pierce
Fairview, NC USA
Hello Goldstar31, apparently amateur machinist on this forum are satisfied with their purchases.
I am also an accountant. I worked 30 years with Internal Revenue Service in the New Orleans, LA office. I was a Team Coordinator with the Large Case program. I traveled a lot, from Nevada (tax issues at a large gold mining operation) to London, England ( issues with a North Sea drilling platform).
Thank you for the informative comments. I hope you get a return on your "investment". I have three Aster garden railway locomotives. Some people consider these an investment. However, there are few young people interested in garden railway today and many old steamers have passed on.
SmithDoor
Clovis Ca
I think I change to better motor.
I have heard of problem on some of mini Mills.
A good motor is needed on lathes and mills.
I would look for a better motor and controller.
