Maudslay Model oscillating steam engine
Discussion in 'Finished Projects' started by cfellows, Sep 2, 2018.
  1. Sep 2, 2018 #1
    cfellows
    cfellows
    cfellows
    Well-Known Member Project of the Month Winner
    Aug 26, 2007
    3,891
    704
    Here's a video of my completed Maudslay oscillating steam engine.
    Lapping the rotary valve to valve block took fixed the last of the air leaks, so now the exhaust is about the only air that is audible.
    Chuck
  2. Sep 2, 2018 #2
    kadora
    kadora
    kadora
    Project of the Month Winner!!! Project of the Month Winner HMEM Supporter
    Jul 1, 2012
    445
    320
    Nice smoothly running unusual engine .
    Did you cast frame for this engine ?
    Thank you
  3. Sep 2, 2018 #3
    cfellows
    cfellows
    cfellows
    Aug 26, 2007
    3,891
    704
    Thanks. The frame was assembled from individual parts. The feet, circle patterned brass insert, and top bridge connector were CNC cut. The sides of each frame are 1/4" brass tubing. All the frame parts were soldered together and fastened to the brass base plate with screws from the bottom.
  4. Sep 2, 2018 #4
    natalefr
    natalefr
    natalefr
    Sep 24, 2017
    148
    44
    Gender:
    Male
    France
  5. Sep 2, 2018 #5
    Cogsy
    Cogsy
    Cogsy
    Well-Known Member Staff Member Global Moderator
    Jul 30, 2012
    2,674
    768
    Gender:
    Male
    Perth, Western Australia
    Beautiful engine and not a design I've seen before. Congrats.
  6. Sep 2, 2018 #6
    spacy
    spacy
    spacy
    Apr 24, 2013
    15
    9
    Occupation:
    Engineer
    Portsmouth. UK
    a very nice engine design and build :)
  7. Sep 3, 2018 #7
    ShopShoe
    ShopShoe
    ShopShoe
    Senior Member
    Oct 2, 2010
    954
    178
    Chuck,
    That's very nice. It reverses so nicely and runs at a nice speed.
    I also like the choices of materials.
    Thank you for posting the build and the result.
    --ShopShoe
  8. Sep 3, 2018 #8
    Rickl
    Rickl
    Rickl
    Junior Member
    Aug 16, 2009
    57
    9
    Thanks for showing the engine. Very nice.
  9. Sep 3, 2018 #9
    chucketn
    chucketn
    chucketn
    Senior Citizen
    Dec 17, 2009
    1,303
    154
    Occupation:
    Fully retired
    Near Jonesborough, TN
    Very nice, Chuck. What was the inspiration for this engine? I have followed most of the build, and want to go through it again, but I can't find it. I see you posted about Maudslay engines many years ago, but this build evades me. Where did it go?
    edit: found it, it was on the other forum... http://www.modelenginemaker.com/index.php/topic,8251.0.html
  10. Sep 3, 2018 #10
    cfellows
    cfellows
    cfellows
    Aug 26, 2007
    3,891
    704
    Thanks, Chuck. I first saw a small sketch of this engine in a model steam engine book I bought at the Kewbridge museum in London probably 30 years ago.
    https://www.homemodelenginemachinist.com/threads/henry-maudslay-steam-engine.1109/
    For many years I looked for other examples of the engine on the internet without success. Then, a couple of years ago I found a picture of a model which had been built many years ago.
    https://www.bonhams.com/auctions/23024/lot/79/
    With a 15 inch flywheel, it was about twice as big as mine and sold at auction for some $35,000. Some years ago I had created some drawings of the engine, not knowing any of the dimensions, but, by studying the relationships of the parts to each other, was able to get a close approximation. Then, several months ago I found a picture of a single cylinder model of the same engine.
    https://www.gracesguide.co.uk/File:JD_2016_J_Spiller.jpg
    With my mill/drill converted to CNC, I decided I could probably pull off the single cylinder version. In the model pictured, the cylinder and crank are mounted outside the frame. I changed the design of mine to be inside the frame. Fortunately, I had cast iron flywheel that was only a little too big and much too thick in cross section, so I thinned out the rim on my lathe and thinned out the spokes on my CNC mill. I also used CNC to cut the circle design brass insert, the feet, and the brass bridge part that supports the crankshaft. The frame sides were assembled from some 12 - 15 parts soft soldered together.
    I never knew for sure how the valve mechanism was supposed to work, but came up with my own design which is probably close. The original drawing and models I found used an eccentric to supplement the cylinder motion, but I was able to design the stroke such that the cylinder motion alone was able to turn the valve enough without the eccentric.
  11. Sep 3, 2018 #11
    chucketn
    chucketn
    chucketn
    Senior Citizen
    Dec 17, 2009
    1,303
    154
    Occupation:
    Fully retired
    Thanks for replying, Chuck. I was also in London many years ago, guided by my my English wife, while I was stationed in the UK with the Air Force.
    Wish I'd paid more attention to the various engines on display back then.
  12. Dec 25, 2018 #12
    Pmcguire
    Pmcguire
    Pmcguire
    Member HMEM Supporter
    Dec 10, 2018
    11
    1
    Gender:
    Male
    Basel
    Beautiful work!!
  13. Dec 26, 2018 #13
    Donrecardo
    Donrecardo
    Donrecardo
    Active Member
    Apr 14, 2008
    39
    5
  14. Feb 2, 2019 #14
    mirek111
    mirek111
    mirek111
    Jan 6, 2013
    83
    121
    Wonderful work!
  15. Feb 26, 2019 #15
    Michel_Mike_Chaput
    Michel_Mike_Chaput
    Michel_Mike_Chaput
    Jul 11, 2017
    18
    2
    Nice engine I like it !
  16. Jul 4, 2019 #16
    bobs7-62steamair
    bobs7-62steamair
    bobs7-62steamair
    Jan 8, 2018
    99
    42
    Hi Chuck: Liked you oscillator engine design. Did u design or acquire set of plans? If acquired where was the source?
    Thanks.
    Bob E.
  17. Jul 5, 2019 #17
    plipoma
    plipoma
    plipoma
    Apr 7, 2013
    12
    2
    Would like to see a close up or a sketch of the valving.
  18. Jul 5, 2019 #18
    gbritnell
    gbritnell
    gbritnell
    Jul 16, 2007
    2,630
    554
    Sorry to say but Chuck is no longer with us. There is a comple Set of drawings in the file section.
    The valve has both longitudinal and horizontal grooves to direct the steam and exhaust.
    gbritnell
  19. Jul 5, 2019 #19
    plipoma
    plipoma
    plipoma
    Apr 7, 2013
    12
    2
    Sorry, I didn't know! I've never accessed the file system, can you please direct me?
  20. Jul 6, 2019 #20
    gbritnell
    gbritnell
    gbritnell
    Jul 16, 2007
    2,630
    554
Draft saved Draft deleted
Share This Page
