Hi All
This is a marine boiler in 4" O.D. Type K copper tube I'm currently working on. I'm fabricating a sight glass with blow down capability and thinking about where to plumb the rest of it. Should a bottom drain be installed and ported overboard? I have two bushes on front and might use one for bottom tap of glass and other for common line for feed pumps. This is a dry back so I might pipe steam out from under dome thru back tube sheet into dry back area. No hole for it yet but aux. steam and psi gauge are in dome now. Will add hole in front of dome for top tap of glass later.I don't know if I needed type K in construction, rather heavy, but in reading various it can't hurt.
Thanks
Johnny O
Thanks
Johnny O
