Paul Gibeault
There is nothing like a perfectly good engine minus 1 tiny bad part urges me to attempt an engine fix. Whilst changing out a piston /cylinder assembly on my O.S. 25LA motor, I noticed one of the wrist pin pads was coming apart. It seems the top of the pad is separating from the rest. This has happened to others also. I'm not aware if these tiny pads are available. This disintegrating pad issue was also a problem on my very high performance K&B 6.5cc speed engines. I was able to get replacements direct from the factory back in the day & I ended up using most of my stock over the years. These days, out of production parts are extremely difficult to come by hence the DIY method is needed.
So, with a scrap of 3/8" Teflon rod, I attempted to make one. In 20 minutes on the lathe it was a success, I think... Only running with tell the true story. I made my replacement pad thicker (close to the wristpin I.D.) so that it needed a tiny squeeze to press in. I also made the brim a bit thicker also (without being too thick to rub on the cylinder wall). The final shape of the 'top hat' was finished by hand with a fine file & sandpaper. This being said, I was wondering if anybody here has any thoughts as to the right way in which to make these tiny pads & any details that need to be kept in mind. Also would nylon work as well for a material??
