rake60
- Jul 8, 2007
- 4,756
- 124
This is a work related story but it always seem to happen the same with my hobby machines.
One of the production turret lathes at work broke down.
The turret would come forward to the collet but would not return.
One of the greatest mistakes in machine troubleshooting is overlooking the simple things.
I wasn't about to do that this time. Start at the beginning and go in sequence.
First I checked the microswitch that is supposed to stop the turrets forward motion. It's working fine.
Next, to the relays that microswitch is supposed to trigger. They are both tripping.
Now check the solenoid controlled pneumatic valve that controls the hydraulic directional valve. It works.
It has to be the hydraulic valve.
Get the maintenance manual out to locate the hydraulic valve.
The diagram shows Hydraulic Valve Q controls the turret forward and reverse.
So I go to a "retired" machine, steal that valve and swap it out on the broken machine.
It still won't cycle.
Look at that diagram again. Maybe there is another hydraulic valve in that circuit.
S#!t, the valve I changed was O not Q! Damn small print!
Change out the REAL Valve Q, the machine cycles perfectly and is back in operation.
Honestly, it always seems to go the same way for me at home! :wall:
Rick
Rick
