Mach 3 help
It looks like
Pin14 on the DB25 is X enable
pin 15 is A enable But 15 is not a valid output pin
16 is Z enable
17 is Y enable
And for A, step pin 5 direction pin 9
thats fine but were do I set the 14,16,17 enable
thanks
Config/Ports and Pins /Output tab
Don't forget to hit "Apply"
We better check the motor tuning page too.
config / motor tuning
I am assuming you are Metric ?
These should be safe for metric, we'll fix it later when you know what screws you are using.
Maybe the Enable will fix the one direction issue.
I'm using imperial
I hook up another controller board
and everythings work enable step but no dir Ill go and check it
thanks
Luc
For imperial use these numbers for now. This would be for a 5TPI screw and 50 inches a minute rapids
Luc
Do you have a link to your motors ?
If they are 4 wire bi-polar and one direction works so should the other.
If they are 6 wire and you wired them for bi-polar, they may be wired wrong.
Scott
Thanks for all your helpth_wav
evrything works finewoohoo1
I'm sending back the BOB'S board back:wall::wall:
and the reason It did not want to switch cw or ccw
is a deffective or could solder board:eek: I didn't check it yet
I simply decide to check another driver boards and it worked fine
and all the other axes also
I will be running a belt drive with a ratio of two to one
cheers
Luc
Great !!
Glad it's going
Scott
Thank you very much for all your help
will fixe the driver and post a video.:D
If you look up in the sky and think it's an Flying Saucer
think again it's that board that I just trown awayRof}
now it's time for one of those
*beer**beer*
cheers
Luc
