RonW
:wall:I have a question. I recently purchased a used Lufkin 513 depth gauge. It worked freely but had a little rust on the spindle and sleeve so I dismantled it and cleaned the rust off with some well worn 400 grit water paper and some WD-40 as a lubricant. I tried to re-assemble it and can only turn the sleeve in about a half inch before the thread seizes. I removed the rod and tried again and the same happens. I have flushed out the threads as well as I can see but the problem remains. Obviously something is trapped in the inner threads, I suspect inside the sleeve. Does anyone know if it is possible to further dis-assemble the sleeve and the spindle so that the threads can be exposed and examined. It looks like it is press fitted but I am not sure and have so far been unable to find any information as to how they are assembled.
