Looking 3-4" lathe chuck with 2 piece jaws?
Help Support HMEM:
dieselpilot
Are there any small manual chucks with two piece jaws, master jaws with top jaws? The closest I found was a Bison 4" chuck with one piece jaws but they offer soft master jaws. This is for the Emco lathe, it won't fit a larger chuck.
Greg
Blogwitch
Ex Bogstandard
HMEM Supporter
Crewe, Cheshire, UK
Greg,
No matter what chuck you go for, if you can get a set of soft jaws for it, then take the opportunity to purchase them.
I have been using soft jaws for years, when soft jaws were nearly the price of a new chuck, and they are the cheapest and easiest way to get high precision turning on your lathe. In fact about 3 weeks ago, I turned up some 0.020", 0.040" and 0.060" thick by 2.5" diameter ali shims on my 5C version of soft jaws.
I have soft jaws for all my lathe chucks from 80mm right up to 6", in fact I won't buy a chuck unless I can easily get soft jaws for it.
Tin Falcon
wow hens teeth.
What spindle thread? 800 watt on e-bay used to have a pretty large selection of small chucks. no joy he has nothing listed now.
e bay has a used craftsman chuck like you are looking for current bid $ 45 plus $12 s&H .
http://www.ebay.com/itm/Craftsman-Wood-Lathe-Small-Self-Centering-4-Jaw-Chuck-3-4-x-16tpi-/110775689625?pt=LH_DefaultDomain_0&hash=item19cabee199
New England Brass and tool has lots of little bison chucks but all single piece jaws. little tommy bar chucks.
I do know of what you speak my edestaal machinex 5 has such a chuck, 3 jaw tommy bar deal with aluminum soft jaws.
I was lucky to get the tooling I did as they are scarce. looks like this
looking closer bison does have a 2 1/3 inch chuck with available soft accessory jaws but a bit pricy about $300 us for the chuck and another $135 for the machinable jaws.
dwentz
The Taig 3 jaw has removable Jaws. They are aluminum. It is 3/4-16 mount, I have a MT3 arbor that is threaded 3/4-16 that I purchased from Little Machine Shop so I can mount the Taig chucks on my Mini Lathe, and with a MT5-3 adapter on my big lathe as well. They also sell a MT-2 to 3/4-16 adapter which works out good for my rotab and indexer. Good to get multi uses on all the different machines.
Dale
dieselpilot
Hmm.. this is going onto a CNC machine and would need to be fairly stout with a speed rating of at least 4000RPM. The Bison while priced at 250-300USD seems like my only choice. i looked at other big name manufacturers, but turned up nothing. I also looked at the Bison 4" 5C chuck. I took a look at the Taig now, but it just doesn't look sturdy enough.
After a lot of searching any chuck manufacturer I could come up with I found TOS of the Czech Republic makes a 4" with two piece jaws. Now, I have to figure out how to get one.
Greg
Blogwitch
Ex Bogstandard
HMEM Supporter
Crewe, Cheshire, UK
Very reasonable chucks are TOS, I have two or three in the smaller sizes and are about as good as any, other than the very expensive ones.
Good luck on your search
dieselpilot
I sent them an email. I'm hoping there is a representative in the US. Google didn't turn anything up.
MachineTom
Senior Member
HMEM Supporter
That is an interesting problem, Nothing better than soft jaws bored to size for accuracy. Next best is an adjustabe chuck like the Buck Set-tru. one piece jaws all of them( 4"). The jaws are not as hefty as say a Burnerd in the 4" size but being able to accuratly center the work is the aim. On ebay those little Bucks are generally lightly used as they are very common on dividing heads. The Myford super 7 has one, much better than the 50 year old Burnerd that was on it.
dieselpilot
I did also find Kalamazoo, Buck, and Pratt Burnerd make some 4" chucks, but no two piece jaws. I was really hoping to find a 4" manual chuck that used serrated jaws like used in CNC chucks. I only found one source, for a manual chuck like this, but 5" and larger.
The TOS is exactly what I want. I'm waiting on a reply. Not sure if I'd send my credit card info over there, however.
dieselpilot
No reply from TOS. I did read online FWIW, that some Pratt Burnerd chucks are produced by TOS now. A little more searching yielded a company in Florida that listed some TOS chucks. I'm waiting on a reply to email, but will probably call them next week.
Group Builder
