Last year I found out what happens if you use a BIG lathe when it's freezing cold in the workshop,
and just after you replace the old relatively thin power cables to big fat new ones (quadrupled the diameter)..
the machine used to rev up gently with the thin power cables, and now clonks to life nearly instantly.. I think it needs a soft-start module now :/
What you see attached here is one of the gear links for the sideways feed of the tool...
happened when switching the feed on, without being anywhere near to the part.
I can't seem to see any signs of corrosion that caused this, so I suspect it's just inferior steel that was used to make the machine, along with the force it's putting out with the new power cable.
A year later.. the machine is still out of service and half disassembled :<
(it's not mine - it's in the workshop of a friend of mine)
