zeeprogrammer
- Mar 14, 2009
- 3,362
- 13
I was turning a bit of 12L14 steel. Nothing different than what I'd done differently before. I think the tool got grabbed and dug into the steel. Stalled the motor.
Reset everything and continued turning. Initially was getting a 'smooth' finish.
Was using power feed. Suddenly, instead of a smooth finish, I got a stepped finished. Several steps. Playing around with it, it looks like the tool keeps getting grabbed a little and digs in.
At one point, I would feed in .005 and it would cut deeper than I expected. The next .005 did hardly anything. It went back and forth like that several times.
Using a carbide insert.
Kept at it cause I was pretty good along and thought I could get through it.
As usual...last step, parting off. Stalled so bad the part moved in the chuck at a slight angle. So done.
I think I still don't have the compound slide gib right. With sufficient oil along the joint you can see it move if you lift it up and down. Looking (remembering) the gib, it seemed small (height).
I've played with this thing left, right, up and down...am I looking at replacing the gib?
Certainly, parting continues to be a heart stopper (or pooper maker) particularly with steel. I'd rather not 'have' to go to a rear parter (and this time there wasn't much in the way of chips before I had problems).
Any other thoughts?
I think the part is salvageable. I think there's enough there to cut off the 'parent stock' (hee) with my handy-dandy bandsaw. Then I'll see about what it takes to clean up. Still work-able if I can't. It's the bottom of a base.
Not much information here. I don't know what might be important.
Sorry to be any 'trouble' here...but I have that reputation ;D.
Any other thoughts?
