Kiwi Mk2 Engine
The Dormier reamer worked out fine. Drilled the hole 1/64" off the centre and reamed it. Trial fit in the rocker arms and all seems OK. Most probably will do the 3mm studs for the bushes.
can i ask y are the holes off center i new to this site .. is it so u can get your vale tappet Clarance
The hole is off center so that you can adjust the clearance between the rocker arm toe and the valve.
Vince
When I have to bend a tube.......
-close 1 side
-fill it to the top with table salt & shake a bit
-close the top than
-bend it
-open the tube & let the salt coming out
Than you have a beautifull bend.
Barry
Hi Barry,
1. Happy New Year.
2. Learnt a new trick from you,using table salt. Seen old time plumbers
using sand.
looks great. I was given one by my father yesterday. It's in a dire state at the moment. I'd love for it to look like yours someday.
Thanks. I saw your photos on another website.
Vince
