Kiwi Mk II
Richard P
London
Guys
I am struggling!!!
I am trying to machine the Kiwi crank and so far I have failed to find the correct cutter. The picture shows the tools I have used all of which have an overhang of around 35mm. The tipped parting tools seem to "wobble" and I fear the carbide insert will spring out. The parting blade isn't really suited to the task and the tool in the rear tool post chatters badly at all speeds. I have cut a relief into the center of the cutting edge. I have tried the tipped parting off blade in the read tool post but it wasn't stable. I believe the tool height is correctly set.
I am sure it can't be that hard but so far I have failed to find a workable solution. I don't know the grade of the rolled mild steel but it came from a very reliable supplier some years ago and was used for general machining is a development model shop. I annealed it before use. It drills very easily.
Any insights would be appreciated.
Many thanks
Mike
Hi Mike, having recently built this engine I've just had a look in the workshop and found the cutter that I used. In the end I went for a pretty sturdy and solid parting blade rather than using an insert cutter. I shaped the edges to give the stress relieving corner radii and then created the central notch with a diamond hone.
By working the cutter from side to side with each cut only a small area of the blade is cutting at any point in time time. I first roughed out the material and then was able to get a very good fine finish cut with this method.
Mike Ginn
HMEM Supporting Member
UK
Hi Richard
Thanks for the info and indeed all the other Kiwi photos you have posted. I did find this crank small end bearing difficult to machine. I should have removed more material on the mill to reduce the interrupted cut which was my main issue. I found that I needed to use the rear toolpost to provide rigidity and I ground the 5.5mm wide tool to have 2 spurs about 1mm wide. Using small cuts and traversing I was able to get to an even cut when the journal was less than 0.5 inch. I then used a tipped parting tool with an overhang of 35mm to complete the journal. I very lightly ground the top off the insert to provide a sharp edge (maybe controversial but it worked). Thanks for the picture of your parting tool. I tried to get a similar profile but I completely failed to grind the shape using either a Hemmingway grinder or a drimmel. I also could not get the 2 cutting points to be square with the shank of the tool.
How did you achieve the profile????
I now need to machine the main journals and I will try to mill as much material away as possible before cutting on the lathe.
Thanks for your help
Mike
