This is all the drawings required to build the Kenneth Wells traction engine. The author gives permission for the drawings to be copied but not?the photos or text on how to build it (Which is fair enough).
You will notice on some pages it is half blank, that is where I've had to blank out photos to comply with copyright but with a bit of thought (and a set of the castings) this should be all you need to make one.
On the first page for the boiler you will see the steam hole and pipe crossed off as this is for the stationary engine. A drawing a bit further in will give you the correct position for the TE.
If you build one be sure to post pictures of it.
View attachment Wells_TE_drawings.pdf
