Karl-Erik Olsryds 2 cylinder boxer engine.
Help Support HMEM:
Cogsy
Staff member
Global Moderator
Perth, Western Australia
Welcome to the forum. Those are some nice looking castings and an interesting looking engine too. I'll be following along with your build.
e.picler
Edi from brazil
Curitiba - Paraná - Brazil
Hi Karl!
Welcome to the forum team.
I will be following your project with close interest. The kit looks interesting.
Is this casting kit available on the marketing?
Good luck!
Edi
bengt-olausson
Active Member
Hi !
No I dont think so, the designer of this engine was Karl-Erik Olsryd. He lived in Sweden
I think he was at least 70 years old 1996, when he did this castings.
He made a lot of engines the most known was a 9 cyl radial WRIGHT engine.
Bengt
bengt-olausson
Active Member
¨Hi Jef. Thank for your kind words.
The steel is SS2541 equal to 34CrNiMoS6.
C 0,3-0,38
Si 0,15-0,40
Mn 06´,60-0,80
P max 0,025
S 0,02-0,035
Cr 1,30-1,70
Ni 1,30-1,70
Mo 0,15-0,30
Hardened to 340-400 Hb.
Bengt
jef-lemmens
Active Member
C 0,3-0,38
Si 0,15-0,40
Mn 06´,60-0,80
P max 0,025
S 0,02-0,035
Cr 1,30-1,70
Ni 1,30-1,70
Mo 0,15-0,30
Bengt
Thanks Bengt , I use most of the time 42CrMo4 for crancshaft and cilinders (for 2 stroke petrol and diesel engines)
Regards Jef
arc
Very nice work! You are really making some headway.
petertha
HMEM Supporter
Very nice work!
Can you tell me about your valve cages. Are they bronze? Pressed in place or held with adhesive like Locktite? I'm interested to see your chamfering tool & the valves when they come along.
ps - just for interest, a 1/4 scale Wright J5 9 radial of the same designer is being built in Japan. He mentioned he had the casting & plans about 10 years before starting.
http://modelicengine.la.coocan.jp/j5140402.html
bengt-olausson
Active Member
Thanks.
The valve cages is made of bronze and held in place with a nut. Probably I will fix them with Loctite 271 when I assembly the engine.
The Wright Radial is very nice engine. I have the drawings but I never bought any castings. I regret that now.
I bought the castings for the Boxer engine at Christmas time 2016 from a guy that had them for many years, but newer start machining them.
2
Group Builder
