- Feb 17, 2008
- 2,326
- 440
I have been using loupes for about 60 years. When I was a young man it was as a aid to building small parts, but now I am legally blind they are a part of my daily life as well as in the shop.
Firs t tip. When setting a loupe down ALWAYS place it with the lens up. First reason is for safety so it does not collect chips and other debris inside which you can dump into your eye when you next use it. That can ruin your whole day. Second, it keeps the inside clean and it is much easier to clean the outside of the lens of oil vapors and spray that ocure in the shop. This not a natural action so you have to train yourself until it is automatic.
Many people have trouble keeping the loupe in thier eye. I never did have a problem until I had a stroke about a dozen years ago and the facial muscles don't work as well as they used to. So here a few tricks that help.
Wash your face or a least wipe the area around the eye with a clean paper towel or tissue. The face is an oily place and this makes the loupe more likely to slip. And while you are at it wipe the edge of the loupe to remove any accumulated oil.
Most loupes have a very smooth molded surface. which makes them slippery. If you roughen the edge of the loupe where the skin grips it it will help a lot. I just wrap a piece of abrasive paper of 220 or 320 grit around the edge and rotate the loupe 2 or 3 times. It does not take much.
Finally a rosin bag of the type that weight lifters use to improve their grip is quite helpful. Mine is about 2 x 4 inches and a 1/4 inch thick. I put it in a plastic box with a lift off top to keep it clean. I occasionally give the box a shake so powder is on the surface of the pad. I just touch the edge of the loupe to to the surface of the pad.
Gail in NM
Gail in NM
