Jacobs keyless chuck loosens when starting the mill.
Discussion in 'HMEM Forum Support & Suggestions' started by Frank Bauer, Aug 12, 2018.
  1. Aug 12, 2018 #1
    Frank Bauer
    Frank Bauer
    Frank Bauer
    New Member
    Jul 23, 2018
    2
    0
    Gender:
    Male
    Wimberley, TX 78676
    I have recently been having a problem with my Jacobs JKP-130-J6 keyless chuck loosening when I start my Bridgeport. It has thrown the drills when I see they have come loose and turn off the mill. Has anyone else experienced this issue? Can the issue be resolved by disassembly and cleaning of the chuck? Any suggestions??
  2. Aug 13, 2018 #2
    Brian Rupnow
    Brian Rupnow
    Brian Rupnow
    Well-Known Member Project of the Month Winner
    May 23, 2008
    10,885
    3,641
    Frank--How old is the chuck, and how much work has it seen? I don't think you can fix that. Try a total degreasing of the chuck. If that doesn't fix it, then junk it and buy another. There are enough things in our shops that will hurt us without trying to save $100 on a worn out chuck.
  3. Aug 13, 2018 #3
    Frank Bauer
    Frank Bauer
    Frank Bauer
    New Member
    Jul 23, 2018
    2
    0
    Gender:
    Male
    Wimberley, TX 78676
    Thanks, Brian. The chuck is about 15 years old but has not seen what I would call "heavy" use. However, it has been a key piece of equipment in the building of my 1.6" Mikado live steam locomotive. I'm planning on giving Jacobs a call tomorrow and hearing what they have to say as well.
  4. Aug 13, 2018 #4
    MachineTom
    MachineTom
    MachineTom
    Senior Member HMEM Supporter
    Oct 20, 2010
    885
    121
    Some years ago I installed new jaws in an Albretch keyless chuck. On their website the direction state Do NOT Lube the jaw carrier. Well I did anyway, quickly found out why. Turn the machine off from high speed and the chuck opens an spits out the drill bit.
    Sometimes the direction really are correct.
  5. Aug 13, 2018 #5
    rklopp
    rklopp
    rklopp
    Oct 6, 2008
    233
    25
    The symptoms sound strange. My keyless chucks would tend to self-tighten from their own inertia during startup acceleration. That is because right-hand rotation tightens the chuck and right-hand rotation is what one normally gets when turning on a mill. The only time I have had issues with inertial loosening is with lightly-chucked flimsy plastic parts in a scroll chuck and lightly-chucked flimsy plastic parts in a collet with a large handwheel collet closer. In both cases, the direction of acceleration is opposite the direction of tightening of the scroll or handwheel.
Share This Page
