I like to do bench grinders
h7eh7e
Ukraine. Krivoy Rog.
I like to do elektrotochilo to bilo not like everyone else. Here's some pictures.
I picked up a few scrap motors from radial arm saws that had a manufacturing defect. They were perfect for grinders and only a left hand nut was needed to secure the stone wheel.
The saw motor case provided lots of clearance for access to the wheel.
That home built grinder continues to provide useful service after years of rough handling. For drill, milling cutter and lathe tool sharpening I use a smaller grinder with green wheel option on one side.
I have found that grinders dedicated to different purposes are ideal. You can't have too many grinders.
Continue. I had the motor rebuild under voltage single phase 220 volts. Here's how I'm doing. I think that from the photos everything is clear.
For 220 volts it is necessary to switch to the triangle. Display additional three wires.
Thank you.
Yellow and blue were full banks.
The paint dries quickly. Nitro enamel
I gave preference to these colors.
He painted with an electric spray gun.
In the photo I think that everything is clear.
