I'll be contrary... I have an old Tormach 1100. Great machine. I'd get another if my house burned down and the insurance paid off (although I'd think about getting a 770 for space reasons.. the thing is big with the deluxe stand). I had one issue with TTS tools pulling out in long cuts on steel, but fixed it by cleaning the oil off the shank and retightening the power drawbar. Never a problem before or since. I don't run huge cuts, but I'm not seeing any chatter over my manual knee mill. I've never heard of the Supra, so this is all from a quick look at their web site--
The Tormach is exclusively a CNC machine. There's no point trying to run it by hand. It is also designed to be a CNC machine, the Supra looks to be a CNC kit added to a manual knee mill (and thus has a manually operated knee), so you've only got 4.5" programmable Z travel. Might be an issue for you, might not.
No provisions for a stand/enclosure/catch tray... necessary IMO if you ever plan to run flood coolant (and I do, a lot). Same for spindle speed-- you'd want to get the computer-controlled speed option for the Supra; 2800 RPM is slow for little cutters and you don't want to be fussing with belts every time you change a tool. The controller SW on the Supra I don't recognize and the price on the Supra quick-change... yeep.
Tormach's support has been great for me-- my machine's on at least it's 3rd owner and they happily help me out with all kinds of things. There's an active user community and parts available. If you want to get into production work, they've got a 10 tool ATC about to release... although if you want to get into CNC production work, pile up $20K (what a loaded Tormach or Supra would be) and go get a nice used VMC which will run rings around both of the other machines.
All that said, what kind of work do you want to do on it? The 1100 itself is overkill for 95% of the work ever seen on here. You can stand on the table and jog it around. The Supra will do better on even bigger pieces of work.
