I've had this happen before - does anyone know the cause or how to counter it.
I'm making pistons for my elbow engine from cast iron, turned from 20mm barstock to finshed OD of 10.0, length 30.5mm with a drilled and reamed hole right through at 4.0mm diameter.
I made two pistons - centre drill, drill 3.0, drill 3.8, ream 4.0 - no problem.
Then I changed to my next piece of barstock (same grade / supplier bought 3 months apart) - first unit came out 0.3mm off centre at the ass end (0.66mm TIR) - useless.
Called myself a few names - checked my setup - 3mm drill a bit dull - silly boy - resharpened - outcome another bad one about 0.2mm offcentre.
I took extreme care with the next one - bad, repeated a fourth time - yet another bad one - Dammit that's four consecutive bad parts.
At this point I gave up and went to leaving the O.D. oversize with the intention to mount it on a mandrel to finish up concentric (which is probably what I should have done in the first place on a concentricity critical item like this).
I made 10 - all of which came out crooked to some extent or the other.
I tried centre drills, spotting drills, brand new drills, checked my tailstock centre ....... nothing worked.
Then I made two more from my remaining piece of the "old" barstock - and they came out spot on.
Coincidence or the material ? 4 out of 4 good ones from the old material, 14 out of 14 bad ones from the new material ?
I suspect (guess) there is a corkscrewing of the grain down the centre of the bar which makes straight drilling impossible.
Anyone out there know what the problem is - or how you can stop it ?
Heat treatment / normalising ??
Ken
Ken
