Home-made buzz-coil from points ignition for less than 3 bucks.
popnrattle
murfreesboro TN USA
For my model engine i'm using 9.6V(3000milli-amp) rc battery for ignition. That 9.6V runs down fast. Couple of hours only. Gonna try to find a 12V rechargeable or greater to increase time between charging. I use my 18V drill battery for my 6HP Stover. That set-up, as you'll see throws a monster spark. Cheap relay switch is the key component. Later, RT.
PopNrattle
Greetings, Being your battery is a ni-cad, it is older and lost it's capacity. I know all of my ni-cad cells capacity is almost gone.
What are you using for a coil? Is your 6 hp an throttler or HM?
If you are using a t-style coil, have you checked the adjustment with a amp meter?
I am using recycled cells from laptops, I have days of running time from this summer.
And on a model engine, sideshaft, particular little beast, I have a coil built by an other model builder- RMC engines.
As I have seen many other people us their power tool battery packs, Lithium- Ion very long lasting.
