I built my first furnace back in 2012, and have experimented with oil and propane burners ever since.
I melted aluminum first, and that was pretty easy. You can melt aluminum as easily as Zamak (in my opinion) using the same propane burner and just slightly more heat.
Zamak has more mass to it.
I really wanted to master pouring gray iron, and that took a while to figure out.
If you know what you are doing, casting gray iron is not much more difficult than casting aluminum, although there is a lot more radiant heat that has to be carefully controlled to protect body and eyes.
The slag has to be carefully handled with iron, but that is really no problem.
Gray iron does not have to be degassed, but you do have to let it cool in the mold overnight to prevent hard spots, and add a very small amount of ferrosilicon.
The burner and furnace must be built to withstand iron temperatures, and the crucible needs to be a high-quality clay-graphite unit that is ferrous-metal-rated (I use Morgan clay-graphite "Salamander-Super" exclusively).
I use a siphon nozzle style burner, and diesel for a fuel, with a flow rate of about 2.6 gal/hr.
Variable speed Toro leaf blower for combustion air.
I will be converting to a gear-pump style pressure nozzle soon, which looks just like a siphon-nozzle but does not use compressed air for atomization, but rather a small gear pump instead.
I had to learn pattern making with machining allowances, shrinkage, draft angle, etc., and now I use a lot of 3D printed patterns.
