- Jul 16, 2007
- 2,971
- 1,035
One thing you might consider while you're at this stage of the build is to see if you can adapt some type of seal (0-ring) into the front and rear main bearings. Even though my engine has very small clearances once it gets warm it does leak oil past the bearing. Another leak area which I don't think can be fixed without considerable modifications to the original drawings is the lifter guides. Here again even with a close fit the pumping action of the liter in the guide tends to draw oil up around the lifter and it seeps down the block. It's not bad but annoying. My engine is mounted to a set of skids made from wood and I have created 2 drip pans from brass sheet which straddle the skid. This help to keep the engine much neater when running.
gbritnell
gbritnell
