Nikhil Bhale
Hello
I bought casting kit for Rider Ericson hot air engine from Myers.
I need some help with them.
While machining the leg I made a boo boo. I tried to take a deeper cut and broke one of the leg. I was thinking about using 2 part epoxy to fix it. Is there any better way to fix it.
One of the other casting is slightly bent. Can I unbend it by applying heat? Or will it be better if I machine it as it is.
Regards Nikhil
