Headstock Mandrel
Help Support HMEM:
PeterDRG
Istria
Hi guys
I welcome suggestions. I made a headstock mandrel for my Boxford, but the cone just revolves instead of pulling up and spreading the end. The one I made for the Hobbymat works fine. Any thoughts on what I should do ?
goldstar31
Twixt Tyne and Tees
imho It has more to do with the INTERNAL diameter and only monute adjuents to the diameter are possible.
I made one to a recognised design for one previous lathe and then bought a lathe with a different diametr and then bought a similar lathe to. the former---- and so on.
I am sure that you will realise that there is literally and expanding wedge. Repeating myself, it is probably less bother to msske a new mandrel body and use the handle only,
Here- some years ago, I saw an expanding bolt anchor designed for goinmg into concrete or brick/stone masonry being used as an alternative.
If that is the case, or possible asight of a builders catologue is an idea.
Norman
BaronJ
Grumpy Old Git.
York, North Yorkshire
Hi guys
I welcome suggestions. I made a headstock mandrel for my Boxford, but the cone just revolves instead of pulling up and spreading the end. The one I made for the Hobbymat works fine. Any thoughts on what I should do ?View attachment 126667
It might just be as simple as pulling the rod back so that the nut grips the inside of the cone.
When I made mine I used a quite shallow taper, a locking taper. This does mean that I have to give the nut a tap in order to release the handle.
Here is a picture of the end of mine.
And one of the other end.
It only takes a single turn of the nut to lock it in place.
goldstar31
Twixt Tyne and Tees
Again, there is - or was. the one on the Chris Heapy site.
It had a handle that could be detached. I used my one on the mill vice.
goldstar31
Twixt Tyne and Tees
Ah, yes. Chris Heapy's site. Recommended reading for all tyro machinists.
The Emerald Isle
Thanks Dave
~There is still a lot of information
For newcomers- like me;)= I like John Moran's GadgetBuilder.com.
There's a bit from our BaronJ about 4 facet drill grinding.
GadgetBuilder would answer a lot of unnecessary questions here
Long may it flourish
Norman
ajoeiam
MN
The Emerald Isle
It is a real pity that the community (of machinists and such like) is not able to maintain and continue such treasure troves of information after the passing of their founders!!
