Handed Stuart Triple
Steamingandy
Active Member
Hampshire UK
Slightly different Stuart Triple this time, it’s will have a bronze base cast from a 3D print (not by me) the rest of the castings are an eBay set of that has had the cylinder block started, but I will need to rework it to change the inlet/outlets over.
The crankshaft is one I made earlier from stainless I will also use stainless for all the steel bar stock, well that’s the plan.
Process I use for manufacture of the connecting rods hopefully the pictures tell the story
And the rest
Hi Steamingandy
I am learning from you build pics, I will be starting these parts shortly and I very much like your method of producing the connecting rods I will do the same when I get to these parts. My build has slowed lately as paying work is being done and a short holiday soon will post again soon.
emers
Hi Steamingandy
emers
Emers
forget to add I did the taper @ 1deg it comes out about right
Steamingandy
Thanks I will keep this thread handy and re visit when I start my parts.
Did you get this kit part completed and where're do you look for them.Love the base casting.
Emers
Just remembered don’t throw the end pice of material it’s perfect for machining the outside of the big ends
I have never seen a solution for supplying oil to the big ends, so I decided to try this a 1.6mm hole through the rod with a countersunk hole at the top under the cross head, it will either work or fling oil over the cross head, we will see.
A little more progress on the handed Stuart triple, the first machining of a newly cast bronze base, it will certainly stand out from the standard engines, the pictures show the process steps.
Emers
The base was cast by a gentleman in the states who is interested in creating a Stuart triple in bronze (no worries about water left after running on steam), I have made some parts for him in exchange.
