kadett
- Jan 2, 2013
- 6
- 15
Hello from Russia! I want to share with you my second engine. The cylinder-piston group used the old refrigerator compressor, piston diameter of 24mm and maximum stroke of 16mm. Spread a small photo report on the progress of construction of the project. I apologize for my English, I use google translator.
The main parts of the engine:
Cylinder and piston
Cylinder head, bronze material. Valve from scraps screws.
Crankshaft and connecting rod. Connecting rod of steel 4mm thick sleeve of bronze.
Prop main bearings are made of bronze.
Camshaft Bearing soldered steel
carburetor
All this is set on the base frame of aluminum 8mm thick.
The ignition system is installed in a box - the cradle.
Engine assembly.
Engine work and ignition:
[ame]https://www.youtube.com/watch?v=gw69cSlppYs&feature=youtu.be[/ame]
Thank you all for watching, I'll be glad to comments. If you can do that attracts a detailed photos.
p.s. what code to embed video in a post?
Cylinder and piston
carburetor
Engine assembly.
