four cylinder plan
Discussion in 'Plans' started by johnlaudano, Jan 6, 2017.
Help Support HMEM by donating using the link above.
  1. Jan 6, 2017 #1
    johnlaudano
    johnlaudano
    johnlaudano
    Jan 17, 2011
    47
    46
    The moderator recently solicited for content so I offer my modest project idea and drawing.
    I recently finished drawings for a four cylinder model engine. It would run on propane and have electronic ignition. The intent was to draw an engine that my antiquated machines could handle and for an engine that would run and be reliable and simple. I'm still not sure I can do it but it keeps me inspired.
    The crank would be supported on the ends only (twin ball bearings each end) and the full-diameter crank weights would serve as a portion of the flywheel mass.
    The pump in the drawing is a dual-chamber gear pump; one side is for raw water and the other for engine oil.
    The external timing gears may be noisy but past experience with belts wasn't successful.
    Alternately, the one I build may be the same design in a three cylinder version with a slightly higher compression ratio.
    View attachment in-line four july 2016-Model.pdf
    View attachment crankshaft in-line four july 2016-Model.pdf
    geoffkingma and H. K. Barrows like this.
  2. Jan 6, 2017 #2
    kuhncw
    kuhncw
    kuhncw
    Apr 13, 2008
    553
    64
    John,
    Thanks for posting your engine design. I like the look of it.
    Good luck with the build.
    Chuck
Share This Page
