Forrest Edwards radial 5
After a month or so working on my hibernating Honda CX 500 , I turned to the leak problem of the pistons. Compression cold is not bad, starting with an electric starter is a piece of cake, and still there is the problem of dying out at full RPM, combined with excessive blowby from the crankcase vent. The obvious choice is to fit two piston rings, like the original.
There was no room on the existing pistons to cut an additional ring groove so I decided to make new ones.
This is the prototype version from mystery aluminium, a strange alloy that could only machined with oil based lubricant
such as WD-40.
Yeah, that is what one would think but.. it is extruded bar stock. I do not know where it came from but it is very brittle.
At the start of the Edwards project I tested some alloys with a home made tensile test device. Is is just a lever with a sliding weight using test bars with a minimum diameter of 2 mm .
This was not exactly testing methodb according ASTM (or any standard whatsoever) but it gave me an idea which material was rubbish and which was not.
When I tried to make a test bar of the mentioned alloy it broke before I finished it so is it really brittle.
Now I remember from the past that the German piston manufacturer Mahle once produced an alloy with a very high silicon percentage for people who wanted to make their own pistons so that would be a possibility but then again, I haven't a clue where the stuff came from.
Anyway, I went on harvesting material form my old diesel piston which is now depleted as far as 20 mm material is concerned.
It gave me sufficient blanks to make a new series of pistons for the Edwards.
When I made the prototype piston I discovered that I could not measure the depth of the piston ring grooves. I made the grooves slightly smaller so I could possibly use left over rings that were rejected because of their thickness.
So I made a pair of attachments to fit over the jaws of my digital caliper, saving me the money for an expensive groove measuring tool that I would hardly use.
The common fault when lost of compression or poor compression: The surface in piston ring groove is not smooth to keep tight against leakage. Use a tiny side rake lathe tool there you can smooth out carefully in the surface in the piston ring groove. And piston ring must be smooth in surface and have a right ring gap calculated by gap vs bore size.
Just finished 5 new two-ring pistons.
On the subject of piston rings: I wonder whether old brake cylinders could be used to make them.
The material is cast iron and is easy to machine. Old brake cylinders can be obtained at any scrapyard for next to nothing ( or nothing at all if you fix your car yourself). The only question is if the material quality is any good. Being a safety item, it should be made of good material ... shouldn't it?
Any comments ?
No problem, the cast iron in the brake cylinder is good quality. I has used brake disc who are made of cast iron to produce piston rings. My model engines has still good compresion after a lot of years. And the cam shaft of cast iron too except the cam is too hard to machine. :)
I used brake cylinders to make piston rings. As they were the only rings i have ever made i can't say it is a good idea or not. My engine is a runner so they do work.
Andrew in Melbourne
After measuring the wall thickness of the piston crowns I found out that they were... well, a bit thin, the thinnest measuring 1,7 mm. Whoops.... Now I can fit them in the engine and see what happens but I'd feel more comfortable if I would know that these pistons could withstand the pressure. Now a long time ago I made a hand operated hydraulic pressure pump, just for the fun of it. It came in handy afterwards. I helped a friend of mine who had the piston of the brake caliper of his old BMW motorbike seized up. With the pump connected, the piston came out quickly. To test the strength of the piston, I made a thick-walled cylinder4 housing with a connection for a hydraulic pipe. The testing object was a previously rejected piston that was adapted to fit an O-ring instead of the usual piston ring .
Wall thickness "t" of the test piston was slightly thinner, 1,6 mm.
I managed to get the pressure to 100 bar, and nothing happened.
From various sources I found out that combustion pressures in four-stroke petrol engines are about 30-40 bar. Even if the pressure in glow engines would be higher and taking in account a reduced strength of the piston material due to high temperatures, I think I 'm am quite safe.
Jos
I hadn't realized peak pressures get that high. I've seen a few generic pressure profiles like this sample plot but had not payed enough attention to the Y-axis. Amazing. The duration at that pressure spike must be very short, but it repeats often & I guess stress is stress when it comes to materials.
https://performancetrends.com/Definitions/Cylinder-Pressure.htm
With the pistons complete I went on to the piston rings. Having made the ring grooves a bit narrower I could use previously rejected rings that were too thin. This meant that the thickness had to be reduced form 1,00 mm to 0,80 mm. Doing this manually would probably result in a lame hand so I made a lapping machine using old parts form various sources.
I replaced the adjustable bicycle bearings by ordinary deep groove ball bearings. The whole thoing conssist mainly of a vertical shaft with an excentrical shaft mounted on top of it. On this shaft there is the lapping disc mounted on two ball bearings .A retainer rod is fitted on the side of the lapping disc to prevent it from spinning around. The rod moves between two ball bearings to reduce friction. The motion of the lapping disc is comparable with the motion of the big end of a conrod.
The ring is kept in place by a plunger-type tool, adjustable to match the thickness of the ring.
There is a ring on the lapping disc to hold the sandpaper in place. I started with grain 100, final lapping was done with 400.
Ingenious! So the sandpaper is held by both the central nut/washer and by the outer ring, right? Any tendency for the sandpaper to pull up, wrinkle, or rip?
I've long contemplated some sort of sharpening contraption using wet/dry sandpaper - that's what I use to get my chisels and planes super sharp, but currently I have to do all the motion, with the consequent danger of rounding over. Something like what you have rigged up, without the oscillating motion, and a tool rest ... hmm ...
Nice job Jos!!
I have one question...What glow plugs do you use?
I am building my own Edwards radial 5 but it seems difficult to find the ones that the plans specify (Fox Long with idle bar) they seem to be really old stuff...
Thanks!!
Nice job Jos!!
Thanks!!
Use OS "F" glowplug for 4 stroke engine.
