coulsea
3d printers are great for making patterns but files seem to be hard to find, so I thought that I should share mine.
The smaller flywheel is from the 140 mm pattern scaled to 0.65 in the slicer program.
The larger one is a 90 mm pattern at full scale, the blue patterns are lumps to provide hot metal to the flywheel as it cools and shrinks, I feed into one and vent from the other. I am using aluminium bronze which seems to shrink a lot. the blob can be used as a two part pattern to give twice the volume but in this case I am only using it in the top half of the flask. If I use the blobs opposite sides of the pattern the center hub shrinks, the placement in the picture works.
The 90 mm pattern has a larger center hub so I can use a taper lock.
The patterns have draft, slightly tapered spokes in both directions and fillets and work quite well, I give them a couple of coats of spray putty to smooth them and the gloss paint on the red one worked really well.
Enjoy
Andrew
Enjoy
Andrew
