First Steam/Air connector finished
deere_x475guy
Eaton Rapids MI
Ok gang, took me a bit to get everything figured out and had to grind a new tool to make the barbs so here you go.
Man these parts sure are small.... ;D
looks good could we get a pic that shows the barb ??
Sure, I just went back out to the shop to take one for you.
4 barbs...none are sharp, 45 degree, outside diam= .188 inside = .150.
Thanks for the drawing and idea.:)
Oh and I just checked, I can't pull this tubing off.
The length of the threads are .150. The hex length is .125 and the barbed part is .211 for an over all length of .486. I think they will work out just fine.
And a piccy of the tool you ground? Form tool for the barbs?
Best,
BW
Hi Bob I am making the second one this evening and will be taking machining pics as I go along and will have a pic of the ground tool.
Ok...here are some pics.
I first turn the threaded end to a diameter of .211.
I forgot to take the pic of threading the part till after I machined the barbs...but anyway I use a die to make the threads next.
Then I use my parting tool to cut the diameter for the barbs.
Here is the tool I ground up today to cut the barbs. I needed something that would let me come in close to the hex.
This is a pic of the barb machining
After the barbs are cut I am suppose to drill next....I did this step on the first two and forgot on the 3rd...guess I should have done this post first and then referred to it.. ;D ;D
Well anyway after the drilling is completed..then I part to length...
Looks great Bob!!! It was so nice here today, that I ended up cleaning most of the day. I got everything ready for tomorrow though:eek:)
Later, Wes
Wes thanks...wasn't a problem for me to be inside today....cold, wet, and rainy here....more tomorrow.
I have 4 done now so I should be able to put a big dent in the 12 I need.
Well I got motivated today to figure out the multiple zero points on this new DRO and after I did the last 6 took about and hour and 20 minutes. Here they are:
I am going to use the little buffing tool on my Dremel to put the final polish on them.
