- Jun 24, 2010
- 2,357
- 931
When I see pictures of people silver soldering or torch heating tool steel for hardening etc, they typically do it on a whitish brick looking material to keep the heat confined & protect the bench. What exactly is that material & where would I typically find it? (Canada). Ideally Id like to buy a few blocks or tiles so I can orient them in different arrangements like the open corner box concept. I saw this (attached pic) at Home Depot but I'm not sure if its meant as cosmetic 'fire proof' material vs. what I should be using.
I just made my first cutting tool from oil hardening tool steel (woo-hoo!). It is small mass material from 0.25" rod stock & only needed the tip hardened so used my propane torch & held stock in flame with vice grips. Seemed to work well but I could tell already it was losing heat & taking longer than it should. I know one day I'm going to have to bite the bullet on an oxy-torch system of some sort. But the test part came out pretty nice so I'm all pumped up about this new found capability. Time to take it to the next level!
