Finishing my Nantong Drill Press
For some reason I always seem to be drilling something that is too deep for my Clausing drill press or wants to run at a faster or slower speed than it will run. When I saw this on Craigslist, I took a shot at it.
It was the typical used and under cared for machine needing lots of cleanup and TLC. I pulled it all apart to find some of the bearings were rough and the 3MT taper chuck was really stuck. These pictures show everything cleaned up and ready to go. At over six feet tall it is incredibly tall so I wasted no time in taking the motor off and removing the spacer block and the cross feed table. It came with a nice stand with adjustable feet.
Although there is some damage to the top of the cross feed table, the gibs and feed screw adjusted nicely and work smoothly. The block where the crossfeed table mounts took some kind of oddball size t-nuts to I took it to the Bridgeport and widened them slightly to take standard 1/2" t-nuts.
There was the usual electrical messes. The input cord was flopping in the breeze, handing down out of the box with wires rubbing on the hole. The box itself was only held in by one screw and the switch was loose. So I fixed each one of these.
The head moves out on a gear. It had about 1/8" slop in it because there were no jamb nuts on the adjusting set screws. In addition, the allen hex heads were broken out. Cleaning, adjusting, and lubing tightened it right up.
One of the nice things about this is the way the head moves out to almost 20" on center from the post.
With the new bearings, the thing is very quiet, surprisingly so. The motor bearings sound new, so everything is tight. I believe you could use this as a milling machine. It uses a 3MT taper collar. It has good sized roller bearings in the quill and the quill works smoothly.
I am looking forward to putting it to use.
Jim
Jim
