Jonesie--Nice job on the Pumpjack!!! Good luck with the Popcorn engine. Be warned that Stew made the cylinder 34mm long, not 32 as shown in his first release of drawings. It will work at 32 mm if you've already made it, but you will have to use a gasket at least 0.020" thick under each cylinder cap to give piston clearance.---Brian
