Donleybill
- Dec 17, 2017
- 13
- 3
Q Has anyone tried to use a flapper disk abrasive pad on their vertical mill? The base of the engine I’m building was originally Blanchard ground which looked ok. After months of building on top I’ve managed to upset it’s original surface finish. My engine build is about finished and I need to address the surface finish of the 1/4” plate 302 SS stock. I don’t want to surface grind. I would rather see fine spirals patterns across the plate. Don’t want to color paint.
Disk sanding on a milling machine is not what it was designed for. If the ways are covered and I carefully clean the milling machine before and after why not? I‘m will double side tape the plate stock to the machine table. Attach a flapper sanding to the spindle. Turn on the spindle and hopefully end up with great results. Is this too stupid or what!
Bill
Bill
