I use a Boxford lathe at home, which is a SB9" clone. I came by an 8" 3 jaw chuck, which is way bigger than the machine can really handle - and of course one must be careful how far out the jaws are, or they'll clout the bed! But - the chuck is deep, and has a large hole up the middle, which helps a lot with holding things which otherwise (in the 4" chuck I used previously) would be a pain. It's not as useful as a 2" spindle bore, as on one machine at work.
I suppose there is a lot of overhang on the front spindle bearing, and the setup will not be too rigid - I tend to use the tailstock for parting, for example. But on balance, given my tight space constraints which forbid a larger lathe at home, I'm pleased with the big chuck.
(Edit - I knew I had a photo on here somewhere - here is the link, though the idea is not very complicated!
Small lathe, big chuck )
