Ellery V-Twin 100cc Design & Build
cbooth
Scotland
Hi all,
Thought I would put progress to date of my own design engine V-Twin, all things going well she will be used for an RC plane I am building.
The engine specs so far are:
Type: V-Twin gas
Capacity: 100cc (2 x 50cc)
Stroke: 3.9cm
Bore: 4.0cm
Compression Ratio: 8.5
Ignition: Spark
I've been designing it in Autodesk Inventor which makes it really easy to take of plans and dimensions.
WOB
Looks good, but I'm curious why you picked a 90 deg. twin instead of a 180 deg. twin considering that the vibration of the 90 will be considerable and the 180 would be zero( assuming a 180 deg. crank)?
cbooth
Scotland
It's 90° V so technically has perfect primary balance, aka Ducati. Also I wanted a V to suit my plane design. The heads will stick out of the cowling.
bruski
That engine and your skills are perfect. If you should put together a drawing package, I would like to purchase a set from you. Great work!
Thanks,
Bruski
cbooth
Scotland
Thanks,
Bruski
Thanks Bruski. Plans are pretty much finished, but wouldn't like to release until I have finished mine and get it running. I occasionally find bits when I am machining that I need to make alterations to on the drawings.
cbooth
Scotland
Thanks!
I think I recognize the pilot in the airplane - that's "Mini-me," isn't it? (From the otherwise forgettable Austin Powers movies.)
close, it's actually Bruce Willis. I downloaded the file and 3D printed him
cbooth
Scotland
today I got the rear crank done. Found it really difficult to get a good finish on the EN16
Also got the first piston sleeve done from Cast Iron, much easier to machine. Made an error by rushing and gouged a mark withdrawing the work piece. Fortunately it'll be well below the piston rings so should not affect anything.
a41capt
Camp Verde, Arizona USA
This is beautiful workmanship! Both engine and airplane are exquisitely executed. o_O
100cc? FYI, I took a 3rd place in my first motorcycle race in 1967 on a 60cc bike. I would’ve loved to have had those extra 40cc, not to mention having them in a V-Twin configuration!
You sir, are an artist!
John W
Peter Vivian
New Member
Amazing work and I'm loving the 'plane, just back into aeromodelling after a 45 year gap!
