- Jan 4, 2011
- 1,332
- 343
I have a blade welder on my DoAll band saw. It is rated 440 volts single phase and uses two wire input. I no longer have 440 but do have 220 volts single phase. Is it possible to use a transformer to get 440 volts and if so what size and or type? Since the welder is capable of welding 1" blades and I want to weld 1/2" blades is it going to just operate at half capacity if I feed in 220 volts or is it going to burn it up?
Edit: Welder is labeled as 10 amp.
