I have just finished making the piston for Jan Ridder's simple two stroke.
It needs to be tapped m5 for the piston rod,and also cross drilled for a pin.
I hadn't read the part about the pin,so only drilled the piston 10mm deep originally.It's supposed to be drilled 22mm deep,so i refitted the piston in the lathe,and drilled ANOTHER 22mm.As I had already drilled 10mm at first,the drill now passed cleanly through the top of the piston! I guess I could make a little plug for it,but pride suggests a new piston to be made.
