DIN Plugs and jacks
jgarrett
I need to find a source for mini DIN chassis mounts and plugs so I can switch my DRO between my mill and lathe. 4 pin would be fine. I have several mouse cables that I can use for the plugs but have not been able to find any chassis mount jacks.
Any help would be appreciated.
Thanks,
Julian
;D ;D ;)
Hi you guys, I'm new here and based in the UK and I am known to BOGSTANDARD, ??? ;D :p so blame him....He He.
A source for both standard and mini-din connectors in the USA is http://www.action-electronics.com
They do both cable and chassis mounted types from 3 pin to 8 pin and with mail Order.
Hope this is of some help.
Best regards.
SandyC. ;D ;D
Also look for S-video jacks-- they may be easier to find and fit the same (if you have the right 4 pins.. more than that will be trouble). If all else fails, you could whack some ends off mouse-extender or KVM cables.
Julian:
Try http://www.newark.com/ IIRC they have a $25 min but check it out could be wrong if you want to do local radio shack carries the 9 pin serialconnectors. I just picked one up last night for a project /repair.they are a little pricey but good for one or two items and no shipping.
Tin
