Demon V8 Gaskets
stevehuckss396
Model Engineer
HMEM Supporting Member
Sterling Heights, MI
Hello Gents!
I was going to setup my mill and vacuum table to cut gaskets for the demon. A model engine forum member offered to cut them with the laser and suggested I make a big pile while the machine was setup. So I did and now i have more than i'll ever need. Even with the fantastic deal on the laser work, I still have more than a few bucks into them. If any of you Demon builders are going to NAMES and are interested I could probably be talked out of some for a small donation. (I'm not a vendor so I cant sell them.)
Hello Steve,
Are you at liberty to disclose the contact and name of the HMEM member who laser cut your gaskets or are you required to maintain confidentiality?
I would be interested in talking to the member since I have also a need for gaskets for two engines.
Peter J.
Hello Steve,
Peter J.
Did'nt say but he contacted me privately so I'm thinking i shouldn't. Sorry!
Peter,
If you want to PM me I also have a laser cutter and work cheap !!
Hello Steve!
I also have your plans and it is likely I will build it this year.
I`m interested on those gaskets. Would you send them to Brazil?
I can reimburse you the postage cost via PayPall as did for the engine plans.
Thanks,
Edi
I have the plans for this engine
I would be interested if you are willing to find out how much postage it is to Australia and give me a total cost
Thank you
Michael
Let me get thru next weekend and then maybe i'll take up a list and do a one shot trip to the post office in a few weeks.
Hi Steve
The Demon is also on my list, can I get a set shipped to Thailand!!!!?
Steve, I've seen some guys on other (RC) hobby forums posting 'will cut' ads with their lasers. Trying to pay them off or augment income I presume. I don't know what kind of machine or wattage but they handle lite ply & balsa etc. If someone wanted to go down that (el-cheapo/hobbyist) path on their own gasket outline designs, did you get the impression there were specific issues relating to the laser or setup or gasket material to be aware of? Are your gaskets Teflon sheet, or?
Somewhat related, another buddy showed me some plastic airbrushing templates he designed & outsourced to a smallish laser cutter service. Not sure what kind of plastic, but I know they are 'solvent proof' & very intricate. I don't recall the price off hand but it didn't strike me as super expensive and it was a one-off. The typical commercial laser shops I've inquired with, the killer seems to be setup fees ebven when you supply the CAD dwg. The per-unit cost comes down with quantity, but that's not good news for the onsey-twosey applications.
They are .010 and .020 thick Teflon sheet.
I was just going to have a few sheets done for myself and figured why not make about 25 incase some of the demon family wanted some. I ordered enough material to make 59 sets. A set is three panels.
2 heads .020 thick
Engine set
Blower set ( includes second carb)
Worst that can happen is if the engine vapor locks a 1/4 thick spacer/gasket will be needed for the base of the carb.
Like you said the setup was expensive so I was going to make special plates for the vacuum table but then I got the offer to laser so I ran with it.
2 heads .020 thick
Engine set
hi Steve
I would like a set
thanks
Luc
