DEMON V8 CAMSHAFT
Gabe J DiMarino
How many degrees apart is the intake lobe from cylinder 1 to 8 ? I know lobe separation between intake and exhaust is 110 . My crank is to print a rod throw every 90 degrees so from 1 to 8 the crank is 180 and the cam runs half the speed of the crank so cylinder one dose 720 degres rotation to complete one cycle . So I'm thinking there 180 apart ? Anyone have a 3d model they could share ? Thank you all.
Hello Gabe!
I'm also working on the same engine, Demon V8 from Steve.
I'm currently modeling the parts on 3D using Fusion360, 95% done.
Here is the Camshaft 3D file. The angle is 115 degrees.
I hope I can start machining the block at the end of January.
TKS,
Edi
  • Demon V8_CamShaft Demon v2.stl
Hello Gabe!
TKS,
Edi
