Dake Steam Engine in 3D by Ernie Daniel
I started looking at these prints and wondering if someone could help me out. The inner piston has the steam ports around the radius and they are not centered?? Why would that be?
one side is .046 and the other is .097
Stew I studied your prints and you put the slots on a radius and they are centered.
Does anyone have Ernie's contact? Maybe he could explain...there must be a reason.
thanks
thanks
Hi
Its quite some time since I built the Dake engine so the details are a little hazey I can remember finding an animation of the engine and I used that to work out the details of the valve ports just kept stopping and starting things and drawing it out and doing a paper cut out and trying it till I had something that I thought would work. If you search enough on the net you will see that the ports don't always look similar on every engine I think the Dake company must have tried different thing to try and get the best performance from there engines.
Not quite sure what you mean but the ports were bean shaped and distributed around the centre and they do work.
Hope this helps
Stew
A little late, but I thought I would answer this question.
This project was started 6 to 7 years ago and was going to be presented in a magazine. I do not remember why, but the drawings did not make it to publication.
I worked with the gentleman who had the original engine/model engine to draw up the plans. Although I worked with him for maybe 6 to 8 months, I can not remember his name, but he was very detailed oriented in translating his engine to my drawings.
Concerning the ports all I remember is the following:
1. He took the dimensions from the original
2. I remember asking a question concerning this, and he stated a reason for the “unusual” configuration, but I do not remember exactly what he stated.
So basically, I am no help at all. Lol
Ernie Daniel
It has been a while since I worked on this engine, and I have moved all of my videos to Vimeo.
Perhaps this new link will work:
https://vimeo.com/user82094693
The story behind this engine is that my Dad saw some information on a Dake engine in an old Audel's book in about 2000, and built a barstock version of a Dake (photo below).
Dad was a free-lance builder, and never built any model engine in an exact fashion.
Dad died in 2006, and so I was able to perserve about 18 of his engines, including his Dake.
I had visions of building a Dake one day, but I wanted a build that was more true to the original Dake design, so I studied the Audel's information, and created 2D drawings for a fairly exact scale Dake engine.
The format is large (ARCH-D which is 24"x36"). These days I generally use an 11"x17" format, which is much easier to plot and handle in the shop.
The Dake drawings I created are below:
(part 1 of 2)
I was trying to get my Dake build published, but the editor of the magazine wanted the drawings done in 3D.
The editor found a fellow named Ernie Daniels, who took the information from my "P.Jorgensen copyrighted 2010" drawings above and made 3D drawings.
The copyright that Ernie added to his drawings is not something I consider valid, since all of Ernie's information was derived directly from my copyrighted drawings, and Ernie had nothing to do with the design of this Dake engine.
So the drawings you see in this post by Ernie Daniels is my drawing information changed in layout a bit, with some nice 3D renderings, but the copyright on this Dake design is mine.
I have posted these drawings on the open internet as free, open-source, for personal non-commercial use only, and so as long as they are used for personal builds, then there is no copyright problem.
Ernie's drawings are very well detailed along the lines of an original:- for my model I very much simplified the design if any one would like a copy of my drawing just drop me a PM with your email address and I'll mail you them.
Stew
I posted my Dake drawings on an old website in about 2011, and a fellow named Stu Hart saw them, and asked if he could build a Dake model from the drawings. I told him that one day I would build and perhaps publish a Dake myself, and so I told him he could use my drawings, but that he should morph his build into something a bit different, and not just outright copy my design.
I have never seen the article, but I am told that Stu published the "Potty Dake" in Model Engineer.
No doubt it was an excellent build, given the engines I have seen that Stu has built.
My "P.Jorgensen copyright 2010" Dake drawings above (posts #27 and #28) are the drawings that Stu downloaded from my site, and these were the genesis for the Potty Dake build that Stu published in Model Engineer. Not really a non-commercial use of my drawings, but it is what it is.
As time progressed, I realized that 2D CAD was a very poor design tool for engine work, and so I started to learn 3D modeling (Solidworks).
Since I had my Dake 2D drawings completed, I used them to create a Dake in 3D.
Here are a few screencaps.
Love it! Have you tried assembling your 3D printed parts for running on air? In another thread, I’ve proposed building Elmer Verburgh’s #5 “Geared Engine” via 3D print. You’ve already printed most of a very unique engine, and I for one, would love to see it run!
nice work,
John W
I think the printed patterns would be a bit rough to run.
I did not print them on the finest setting.
I have seen some folks run 3D models.
And I am setting up the assembly in Solidworks, to run it virtually, and if the clearances are not correct, it will not run in simulation.
I have told some folks (magazine editors) that I know my designs will run, and they say "well nobody has ever built or run one, and so how do you know?", and I say "I have run it virtually, and it won't run virtually if there are any inteferences".
I can rotate the flywheel and see things move. I have not gotten all the parts assembled yet.
I will try to make a short video.
Well I can’t wait to see your castings, and eventually, the completed engine.
John W
@GreenTwin
Please forgive my ignorance. What is the valving system on the left side of steam chest in the photo of post #26?
I have moved all my Dake posts to this thread:
https://www.homemodelenginemachinist.com/threads/dake-engine-by-pat-j.34331/page-2#post-381823
Earnie was a person who was brought in by an editor to make a 3D model for a Dake using my 2D drawings.
I have started a new Dake thread because Earnie has nothing to do with my the Dake build, and he ended up here through an odd situation where he worked for a week or so for an editor doing some freelance 3D modeling work.
Please follow along with my new Dake engine build link above.
I will post a response there.
Thanks
