Cylindrical Grinding (Germany)
Discussion in 'General Engine Discussion' started by MuellerNick, Oct 22, 2012.
Help Support HMEM by donating using the link above.
  1. Oct 22, 2012 #1
    MuellerNick
    MuellerNick
    MuellerNick
    Oct 5, 2012
    398
    188
    Hi!
    I do have a Myford MG12-M cylindrical grinder.
    I completely restored it and geometrically scraped it back to Schlesinger-specs.
    Before ...
    in between ...
    and after restoration.
    It now holds 1 µm (within metrological limits; that's 0.0004").
    Some work samples:
    Shafts for alignment tool (metrological device)
    Water pump shaft (5 fittings)
    Shaft adapter.
    Differential gear cage for WWII BMW sidecar. I just face-ground it.
    Forgot what that was for.
    Reducing an MT4 to MT3
    Collet holders (to go into the Myford).
    Work envelope is: Length 300 mm (200 preferred)
    Diameter: 120 mm
    Work holding: Between centers, 3 jaw chuck, collets
    Cones up to 20° (depends on work length)
    Radius dresser, tangential dresser
    Sinuskator (metrological instrument, sine bar to be used between centers).
    Nick
    Henry likes this.
  2. Oct 22, 2012 #2
    crankshafter
    crankshafter
    crankshafter
    Jul 17, 2007
    367
    22
    Hi Nick
    Wish it was mine:rolleyes:
    Werry nice work. Are those arbors W20 aciera/deckel?
    I'm in nead for some arbors for my Aciera F3. but I will have to do them on the lathe:rant:
    I'm following your thread on The MAN engine aswell. What a project:eek: werry informative.
    Best reg.
    Crankshafter
  3. Oct 22, 2012 #3
    MuellerNick
    MuellerNick
    MuellerNick
    Oct 5, 2012
    398
    188
    No, they are Myford-specific. They do have an internal thread for the drawbar. Very British indeed. ;)
    Nick
  4. Oct 22, 2012 #4
    vcutajar
    vcutajar
    vcutajar
    Nov 6, 2011
    859
    145
    Nick
    Congratulations on your successful restoration of the grinder.
    Vince
  5. Oct 23, 2012 #5
    MachineTom
    MachineTom
    MachineTom
    Senior Member
    Oct 20, 2010
    851
    114
    Nick, it sure looks much nicer than mine. I would like to see a photo of that sine bar, and how it is used. So far I've been using a DI on the bed with gage blocks which gets close, but they its grind, measure, twist the knob, then grind, measure, twist the knob.
    As the workhead and the tailstock are not within .003" of each othe,r a slight hump in the bed. each movement of the TS presents a new alignment position. Of course it only matters when it matters, any lathe guy would be smiling if he is only off .001" over 6". If grinding, .0003" is a loose number.
    But it's a time thing dialing in the machine for each setting of the TS.
    Yeah, a few collet adapters for that odd workhead spindle are in the que, as well.
  6. Oct 23, 2012 #6
    Anko
    Anko
    Anko
    Entusiasta
    Jun 30, 2010
    138
    51
    I have to get me one of those! :eek:
  7. Oct 23, 2012 #7
    MachineTom
    MachineTom
    MachineTom
    Senior Member
    Oct 20, 2010
    851
    114
    Nick, You need another 2 zeros for a Micron, 1um= .000004"
  8. Oct 23, 2012 #8
    MuellerNick
    MuellerNick
    MuellerNick
    Oct 5, 2012
    398
    188
    We should meet in the middle, it is 0.00004" (0.001 / 25.4)
    I have seen your Myford and I thought I'll make you a bit jealous.
    But your's has the swiveling work head, so I'm even more jealous. :)
    Don't worry, I also have to re-adjust the table after moving the TS.
    Here's the Sinuskator-thing. I won't tell you how much I paid.
    Nick
Share This Page
