Coil winder
Discussion in 'The Break Room' started by doc1955, Jan 27, 2019.
  1. Jan 27, 2019 #1
    doc1955
    doc1955
    doc1955
    Gone
    Aug 27, 2009
    1,124
    78
    Occupation:
    Retired Former Tool Design Engineer
    Well started winding my first coil I wound the primary which went pretty good and started on secondary (12,500 wraps).
    I've got a plan for the vacuum chamber in mind and going to start as soon as I get the first one wound up. The wider that I built is working well.
  2. Jan 27, 2019 #2
    tornitore45
    tornitore45
    tornitore45
    Well-Known Member HMEM Lifetime Supporter
    Jan 17, 2009
    822
    132
    Hats off to anyone tackling a 12,500 turns winding with a hair sized wire.
    My experience with HV suggest to use a multi section bobbin to lover the gradient.
  3. Jan 31, 2019 #3
    doc1955
    doc1955
    doc1955
    Gone
    Aug 27, 2009
    1,124
    78
    Occupation:
    Well did get my first coil done AND IT WORKS. I now need to incase it I'm planning on a box a smaller version of a model T coil. Here is a pic I took from the video.[​IMG]
    Stefan-K and Buchanan like this.
  4. Feb 1, 2019 #4
    Ghosty
    Ghosty
    Ghosty
    Well-Known Member Project of the Month Winner
    Sep 21, 2016
    369
    307
    Gender:
    Male
    Occupation:
    Retired
    Ulladulla NSW Australia
    Doc, it looks good, this is what I use as a vacuum chamber, made from a glass dome from an old outdoor weather proof light fitting. Made the base of some alloy plate, with a rubber seal glued to it.
    I have an old Robinair vacuum pump to run it.
    Andrew
  5. Feb 1, 2019 #5
    doc1955
    doc1955
    doc1955
    Gone
    Aug 27, 2009
    1,124
    78
    Occupation:
    How do you keep a constant temp? With the process I'm doing I have to hold a temp between 185F to 205F depending on the vacuum pulled.
  6. Feb 1, 2019 #6
    Ghosty
    Ghosty
    Ghosty
    Sep 21, 2016
    369
    307
    Gender:
    Male
    Occupation:
    Retired
    I use it to pull the lacquer into the coil and than bake separate. You could set the whole thing in an old oven to keep the temp.
  7. Feb 1, 2019 #7
    doc1955
    doc1955
    doc1955
    Gone
    Aug 27, 2009
    1,124
    78
    Occupation:
    I don't think the wife would allow that LOL. Plus the temp boils off any moisture the reason for trying to get wax sucked in mainly to keep out moisture.
  8. Feb 1, 2019 #8
    Ghosty
    Ghosty
    Ghosty
    Sep 21, 2016
    369
    307
    Gender:
    Male
    Occupation:
    Retired
    Doc, put a glass of cold water under vacuum and see what happens, moisture is not a problem.
  9. Feb 1, 2019 #9
    Ghosty
    Ghosty
    Ghosty
    Sep 21, 2016
    369
    307
    Gender:
    Male
    Occupation:
    Retired
    I did say old oven, not the good wifes one
  10. Feb 1, 2019 #10
    doc1955
    doc1955
    doc1955
    Gone
    Aug 27, 2009
    1,124
    78
    Occupation:
    Yes you did but I would have to use hers and that would go over like a lead balloon LOL
    The crock pot actually worked great for what I wanted and now that I have that setup thats the route I'm taken the only thing I might change is get a longer hose for the pump.
    I'm going to wind another coil and shoot for 3 to 4 volt and see if I can get it that low and work ok.
  11. Feb 1, 2019 #11
    WOB
    WOB
    WOB
    Sep 12, 2013
    193
    36
    You are overthinking the vacuum chamber. A simple Mason style canning jar with a hose barb in the lid makes a perfectly good one. If you need temp control, simply immerse the jar in a water bath.
    WOB
  12. Feb 1, 2019 #12
    doc1955
    doc1955
    doc1955
    Gone
    Aug 27, 2009
    1,124
    78
    Occupation:
    Yes I do that some times LOL. But I have it all set now.
    Thing is with a jar I would like to know the vacuum value and to get a gauge on it it would have to be a small gauge or a hose to a gauge.
  13. Feb 1, 2019 #13
    barryc
    barryc
    barryc
    Jul 7, 2010
    7
    2
    Warwickshire, UK
    When I used to wind HV coils for vehicle Capacitor Discharge electronic ignitions units back in the 60's, I'd immerse the coils in a jar of lacquer then put it into a depressurisation chamber. (The chambers were used to calibrate altimeters - I was in the RAF at the time - so they were pretty handy!) The reason for employing a vacuum is to remove all the air from between the windings to prevent movement ("singing") of the coils during use. It has nothing whatsoever to do with moisture!
  14. Feb 1, 2019 #14
    doc1955
    doc1955
    doc1955
    Gone
    Aug 27, 2009
    1,124
    78
    Occupation:
    That might be but I am going by the book Bob Shores and he sounds like he was a much smarter individual than I when it comes to mags and coils. So that is what I was going by it is a very interesting book that he wrote and I did learn a lot by reading it like figuring out the length of wire needed to obtain the resistance of a primary winding. Before I read the book I had no clue.
  15. Feb 1, 2019 #15
    tornitore45
    tornitore45
    tornitore45
    Jan 17, 2009
    822
    132
    The vacuum is pulled to remove the air so the varnish can reach every place trapped air would impede the impregnation. At that level of vacuum moisture boils off and leaves with the air. If any air is left a corona discharge takes effect, not a spark just corona. Corona is ionizing and leads to early failure, then you get a real spark inside.
    To test for presence of corona we used to connect the shorted secondary to the HiPot AC 60Hz and the secondary to the HyPot return by means of a 1kohm resistor. Then we look at the V across the resistor with a scope. The 60 Hz is hardly visible but the presence of corona is indicated by high frequency burst appearing on the top of the 60Hz crests. If you see that the coil or transformer is going to fail prematurely in continuous use. A model engine coil may not fail during the few hour the engine is run if that is how long one runs his engines.
  16. Feb 2, 2019 #16
    dsage
    dsage
    dsage
    Jan 1, 2011
    322
    64
    Was there a typo in there? I'm not understanding that setup. You said you shorted the secondary and connected it to the Hipot tester than you also connected the secondary to the Hipot tester. I'm confused. I'd like to try this test. Could you elaborate.
  17. Feb 2, 2019 #17
    tornitore45
    tornitore45
    tornitore45
    Jan 17, 2009
    822
    132
    My bad. The second word "secondary" should read "Primary".
    In other words the HyPot is connected BETWEEN primary and secondary to stress the insulation between them. With this method there is no stress between layers of the secondary, to do this would require a HF induced voltage.
    The idea is that if one does not detect corona in the insulation between primary and secondary there is good hope that the varnish has penetrated the secondary as well.
  18. Feb 2, 2019 #18
    mohavegun
    mohavegun
    mohavegun
    Jan 15, 2018
    47
    14
    Made my vacuum chamber as a "bell Jar" using a sheet of rubber mounted on an aluminum plate. I bought a large clear glass bowl like one would use in the kitchen. A hose barb was fitted through the bottom of the aluminum and rubber plate and hooked to my vacuum pump receiver. ( I use a receiver to build a vacuum reserve) It works very well for degassing investment plaster used for lost wax castings and would be perfect for the coil builder as well. The spherical shape of the heavy bowl is safe enough to support the vacuum. Will send some pics later.
  19. Feb 15, 2019 #19
    doc1955
    doc1955
    doc1955
    Gone
    Aug 27, 2009
    1,124
    78
    Occupation:
    Here are some pics of the finished coil. It puts out a nice spark at 6V. The primary resistance is 3.0 ohm and the secondary is at 5600 ohms. I'm happy with the way it turned out one more thing I can cross off my would like to build if I could.
    [​IMG]
  20. Feb 15, 2019 #20
    mayhugh1
    mayhugh1
    mayhugh1
    Project of the Month Winner!!! Project of the Month Winner HMEM Supporter
    Oct 24, 2007
    904
    2,702
    Occupation:
    Retired Engineer
    Central Texas
    Your photos didn't show up here, but I found them on the other forum. Interesting project and nice final result. I noticed your comment about wanting to rebuild a Model Z buzz box. While watching some of your videos I bumped into one by a guy who showed how he rebuilds the 100 year old Model T boxes. He claims the most common failure is the internal capacitor, and shows where it's at under the tar and how he digs it out. There is also a glass separator plate that has to come out to accommodate the size of a modern replacement cap. I can't begin to recount the number of high voltage projects I built around those boxes when I was in junior high school. Even today the smell of ozone brings back fond memories of those days. - Terry
Draft saved Draft deleted
Share This Page
Group Builder
