CNC face height milling
Hi all,
After the pocketing operation and slot face milling, the face height has to be milled:
https://www.youtube.com/watch?v=uyMMjNYjF3c
Laurent
Nice video! The router looks like it is made out of wood, do you have overall video or pics of the machine itself? I've been floating a lot of different router designs around in my head so adding to the catalog of designs can be helpful.
Just for fun I ran you numbers through Gwizard. It gave a feed rate of 1317mm/min with a 5mm 2fl end mill .725 DOC.
I don't know if your machine can handle that speed but if it can your machine time would be cut in half.
Gwizard is a great program for figuring feeds and speeds.
I had a look at Laurent's youtube channel. The parts being made are custom wheels for a golf cart replacing some plastic wheels.
That's what i was saying on the pocket thread. It is wood and probably stepper motors so i dont know if it can achieve that feedrate.
Any way, you'll get a better finish by slowing your speed or increasing feed.
If you go on my youtube channel you will find many detailed informations:
[ame]http://www.youtube.com/watch?v=LerjdM1zxrY[/ame]
Laurent
Thanks Dave for the informations. I use G wizard but for other stuff. The wooden base is not stiff enough for a .725 DOC. Regarding the 1300 feed rate, as I build axis with stepper motor they lost torque when speed increase . At 1000 mm/min I loss 50% of torque :wall:
See this video:
[ame]http://www.youtube.com/watch?v=6riATIh-4Vg[/ame]
Laurent
