chuck on the front of head stock
Discussion in 'Machine Modifications' started by Don Huseman, Feb 12, 2008.
  1. Feb 12, 2008 #1
    I make 3 and 4 ft long taps. I turn down the shank of a tap and then I bore out the Id of drill rod. I make a .0002 interference fit and heat shrink it on. So far I have only had one tap break loose. To hold the drill rod I use a three jaw in the normal chuck position and to hold the other end of the chuck I mounted a 4" three jaw on the spindle of the front of the lathe. It works great. The only problem I have is I every now and then use my collet draw bar and have to take the chuck off to mount the draw bar opener and closer . About 20 minutes to take the chuck of and mount the collet. I haven't quite figured out how to show pictures yet but when I do I will show you the three chucks I have mounted on my lathe and use all of them at one time.
  2. Feb 12, 2008 #2
    BobWarfield
    BobWarfield
    BobWarfield
    Dec 27, 2007
    1,151
    1
    Don, if you want to, email me the pix and I'll put them here for you. Send them to bob "at" thewarfields.com.
    Best,
    BW
Draft saved Draft deleted
Share This Page
Group Builder
