Rog02 said:. A folded design is the easiest and can be done with a simple shop built heater made from some scrap wood, aluminum, and a piece of heating element from an old space heater or toaster oven.
Circlip said:If you heat polycarbonate incorrectly little bubbles form inside the material, looks real pretty, but is a dog to see through.
Loose nut said:I have a 220 volt "contractor" shop heater that should do the job then, I just need to make the forms for it.
Thanks
Cedge said:Last shield that I built, I used an inexpensive heat gun from Harbor freight. I gently heat formed the lexan to contour to the frame I'd made to mount it. Had to keep it moving, as I recall. The heat gun also drys Dykem quickly when you are too impatient to wait on it.
Steve
Loose nut said:Here is an add on to my question, since I have never worked with these materials before, I realized I don't know what is the best way to cut lexan or plex, band saw,table saw with plywood blade maybe?????
