You will find that C channel is far more rigid than steel plate. You could even use some square tubing, fill it with concrete, like a Taig lathe for even more rigidity. C channel though is simple enough.pete said:Very good idea for those with this type of lathe. I own a Emco compact 5 lathe sitting on 1 IN. thick 12 in. x 27 in. steel plate. Useing the screw adjustable steel plates I bought with the lathe I can adjust this lathe to cut within .0002 for parallel over 12 in. My biggest problem in maintaining that level of adjustment, Is the construction of the floor, Wood joists, no concrete under the main supports and the plate under the lathe spans two benches at a 90 degree angle. So with all of the above, If I have a very critical part to machine I have to re-tune for parallel and machine to completion as quick as possible. Your system appears to be far more stable than mine.
Pete
