Centring in a 4-Jaw Chuck
Discussion in 'Tips and Tricks' started by stackerjack, Sep 14, 2019.
  1. Sep 23, 2019 #41
    Gordon
    Gordon
    Gordon
    Jan 4, 2011
    628
    83
    I have an indicator which I can mount in my tool post but when I move the carriage I have to move the plunger back by hand in order to get it back into position. Being a clumsy oaf I end up moving something during this process.
  2. Sep 24, 2019 #42
    goldstar31
    goldstar31
    goldstar31
    Feb 20, 2010
    2,372
    525
    Gender:
    Male
    Occupation:
    Haggis Breeder
    Twixt Tyne and Tees
    So what happens when the raw piece of metal is not a regular plane figure- in other words literally a lump where a centre has to be picked up? I've a couple of spring loaded 'wobblers' in my tool kit for such eventualities. Again made to the George Thomas designs . I never quite fancied the old 'Sticky Pin' method with the use of a child's modelling clay.
    Ah Yes!
    Norm
  3. Sep 24, 2019 #43
    Cogsy
    Cogsy
    Cogsy
    Well-Known Member Staff Member Global Moderator
    Jul 30, 2012
    2,671
    767
    Gender:
    Male
    Perth, Western Australia
    I use math for instances like this. Measure to determine the point that need centering relative to the surface of the material and determine the offset required, then indicate as normal but instead of aiming for a 'zero' reading between the two sides I'm looking for the correct offset (hopefully in the correct direction if I've been paying attention). Then I check it visually with a dead centre in the tailstock simply to confirm my process/math. I know my eyes can't tell if it's a couple of thou out but I figure if I've made a math or directional error it's going to result in a large, visible error.
  4. Sep 24, 2019 #44
    goldstar31
    goldstar31
    goldstar31
    Feb 20, 2010
    2,372
    525
    Gender:
    Male
    Occupation:
    Haggis Breeder
    Twixt Tyne and Tees
    I confess to being lazy so with a wobbler of sufficient length, the error is greatly magnified.
    As it's a time for confessions, I never thought of doing it by maths- so thank you
    Norm
  5. Sep 24, 2019 #45
    Noel Gordon
    Noel Gordon
    Noel Gordon
    Aug 20, 2018
    12
    2
    Gender:
    Male
    Napier,,,, NewZealand
    Hi All,, It would seem that ALL pro machinist abhor the thought of using 2 keys but hobby machinists think it a good idea.. Just a thought for you all,just think what it would do to you if you forgot the back key what would happen when you hit the start button on a lathe with a 10 feet dia chuck !!! think about REAL carefully I have personally seen the results of a dumbo doing this and its NOT nice to have to clean up the resulting mess.. Just a final comment from me..it dosent matter if it 10' or 4 inch it will still hurt like all hell if the key catches you..
  6. Sep 24, 2019 #46
    ALEX1952
    ALEX1952
    ALEX1952
    Active Member
    Jan 17, 2018
    35
    6
    In reply to Cogsy you are quoting two different opinions mine is the one in bold type the other is from Noel Gordon, however I completely agree with his comment regarding chuck safety, even for a small machine it is bad practice which will eventually become normal. The potential for serious injury is unthinkable, if you do it in your own shop you will probably get away with it as the key nearest to you will invariably go up and over the back the rearmost will go down and probably stall the machine. Why do you think some manufacturers of lathes, chucks etc put a spring on their keys yes it is a safe guard which most people remove because its a pain but but mainly it is because they recognize the danger and do this to avoid a law suit. Also don't work over a chuck and if you must, isolate the machine, you may not turn it on but somebody else might, some machines are operated from the saddle by a lever which can easily be nudged the one that springs to mind is Colchester Student which will be found in many a hobbyists shop.
  7. Sep 24, 2019 #47
    Andy Munns
    Andy Munns
    Andy Munns
    Feb 7, 2019
    15
    0
    Gender:
    Male
    Australia
    School metal shops teachers will growl at students for parking keys in chucks. Students and apprentices are taught never to do this and that the chuck key must always be held, or rested in the chip tray. There have been many case examples of broken or injured hands, etc. plus broken windows, holes in ceilings, etc. My navy mate describes in detail the serious punishment he received when as an apprentice artificer/stoker he parked a chuck key in the chuck.
  8. Sep 25, 2019 #48
    kuhncw
    kuhncw
    kuhncw
    Well-Known Member HMEM Supporter
    Apr 13, 2008
    679
    84
    USA ILLINOIS
    Noel, when I use two keys (or one key), the key comes with my hand when I pull my hand away. I certainly agree that a key left in a chuck is dangerous.
    I also understand why using two keys in a chuck large enough such that you cannot not hold both keys at the same time would be extremely dangerous.
    Chuck
  9. Sep 25, 2019 #49
    Cogsy
    Cogsy
    Cogsy
    Jul 30, 2012
    2,671
    767
    Gender:
    Male
    I don't see the issue here at all - as I said clearly, and Chuck is also saying, is that we never let go of a chuck key when it's in the chuck. This method means you will never have a chuck key ejected from the chuck if it's accidentally overlooked. It seems the pro machinists are in the habit of taking their hands off a chuck key while it's still in place. I caught Joe Pie doing this in one of his early videos - several people mentioned it in several videos and he issued the challenge to point to a time stamp where the chuck key was visibly in the chuck with no hand on it. When I pointed out such a time stamp he responded with something like "a bit harsh, it was only for a couple of seconds and my hand was never more than 6 inches away". You can decide if it was harsh or not. I notice in his later videos the chuck key is usually not visible at all (I think Joe is great by the way). It seems that old adage is true - familiarity breeds contempt. We hobbyists who don't spend 40+ hours a week, every week, in front of our machines are more rigorous about chuck key safety than the 'pros'.
    Also, I never work 'over' a chuck. As my dial indicator is mounted on the cross slide, it reads the top surface of the workpiece. So the keys are used top and bottom of the chuck, I'm certainly not straddling it. My lathes are also not the type with a clutch where the lathe can be kicked into gear by a lever unexpectedly, they require a button push from the operator. So again, I don't see the problem (unless you're a pro who leaves chuck keys in place without a hand on them ;)).
    goldstar31 likes this.
  10. Sep 25, 2019 #50
    wallyblackburn
    wallyblackburn
    wallyblackburn
    Jun 29, 2009
    11
    1
    8th grade metal shop...we were going to work on the lathe! One kid had been bragging all week how good he would do, because his dad was a patternmaker. Not sure why he felt that would impart any special powers to him...but...
    He, of course, was the one that started the lathe with the key still in the chuck. It slammed the key into the bed and stopped. In a panic he reached for the stop button and hit...reverse! Slam! in the other direction.
    Fortunately, it never left the chuck.
  11. Sep 25, 2019 #51
    tornitore45
    tornitore45
    tornitore45
    Well-Known Member HMEM Lifetime Supporter
    Jan 17, 2009
    789
    130
    Yap, I have seen several Video of professional that I respect but can beat them with my two keys method. Turn slack, turn tight, too much, turn slack, turn tight, almost there, turn slack, turn tight and so on.
    As for the key in the chuck. I leave it all the times. Is not that is parked there for an extended time, but in the same operating frame of centering or swapping out a part is no big deal. Way would I start the lathe if centering and tightening the part was not completed. My lathe can not be started accidentally. Even that argument has limitations. If it is possible to "bump" a lever and start the lathe then it can happen while the key is in your hand and inside the chuck.
    Rather than worry about being absent minded (I am not) I would worry about a lathe that can be started accidentally moving a lever.
    When I was in 8th grade I worked on a Grazioli-Fortuna. The motor was always running and you started the chuck with a lever at your left.
  12. Sep 25, 2019 #52
    110samec
    110samec
    110samec
    Active Member
    Jul 28, 2012
    43
    15
    Occupation:
    Marine Engineer
    Anglesey, North Wales
    Of course the chuck key left in the chuck predicament can be solved with one of those chuck keys with the spring on them, making it impossible for them to be left in the chuck
  13. Sep 26, 2019 #53
    nealeb
    nealeb
    nealeb
    New Member
    Jun 24, 2014
    4
    2
    First thing I've always done on getting a chuck with one of those "safe" keys is take the d****d spring off it! And that's before I've tried using it to centre work in a 4-jaw...
    john_reese likes this.
  14. Sep 26, 2019 #54
    110samec
    110samec
    110samec
    Active Member
    Jul 28, 2012
    43
    15
    Occupation:
    Marine Engineer
    They are annoying, however you will never leave one in a chuck even accidentally
  15. Sep 27, 2019 #55
    goldstar31
    goldstar31
    goldstar31
    Feb 20, 2010
    2,372
    525
    Gender:
    Male
    Occupation:
    Haggis Breeder
    Twixt Tyne and Tees
    Today is a time of litigation. I'm not sitting in judgement one way or another but if a spring is removed from a chuck key and there is an accident, who is responsible? The employer has in goof faith and care for his employees tried to ensure their safety. The onus, it seems will fall upon whoever took the matter into their own hands. It suggests that a claim can be made and if proven, the perpetrator will feel the 'Majesty of the Law'
    Again, the person who sets an apprentice to clean floors instead of learning a trade is denying the apprentice his agreed opportunities for a rightful living.
    I'm in a midst of something 'interesting' and wittingly or unwittingly, my affairs are a matter for the police i the first instance.
    There you are- your homework for the weekend:D
    Norm
  16. Sep 27, 2019 #56
    GRAYHIL
    GRAYHIL
    GRAYHIL
    Jul 22, 2010
    89
    10
    Just take the lathe out of gear.
    Graham
  17. Sep 27, 2019 #57
    Dubi
    Dubi
    Dubi
    Active Member
    Jan 9, 2018
    35
    5
    Gender:
    Male
    Occupation:
    Designer of Wet Submersibles
    Indonesia
    In my shop if you leave a key in the chuck you are fired. Very simple and plain to understand.
  18. Sep 27, 2019 #58
    nealeb
    nealeb
    nealeb
    New Member
    Jun 24, 2014
    4
    2
    In my single-user home workshop, no-one to sue but myself! Have to agree that things are different otherwise. However, I first took a spring off a chuck key when I found the spring so strong that I seriously risked eventually rounding the key or the key "hole" as it was so difficult to keep it engaged when tightening. Would have made fine control of the key for centring difficult as well - although the spring didn't last long enough for me to find out! Still, I'm a "single-key and hold it in my hand" user, and while two keys in a 4-jaw might make centring quicker, I doubt if it would make that much difference. Like, for example, when aligning a machine vice using DTI and soft hammer, you get a feel for how big a correction you need to allow for retightening the other side. I do like the idea of rubber-banding four slips to the faces of a rectangular piece of work, though. That one goes in the "remember for the future" category.
  19. Sep 30, 2019 #59
    KellisRJ
    KellisRJ
    KellisRJ
    Ron HMEM Supporter
    Apr 13, 2018
    17
    1
    Gender:
    Male
    Occupation:
    Security
    Alexandria, VA (USA)
    On chuck keys. I read about this on a forum, and knowing my own limitations, made one too. A key hook with a proximity switch. If the key isn't in the hook, the lathe won't run.
  20. Sep 30, 2019 #60
    Gordon
    Gordon
    Gordon
    Jan 4, 2011
    628
    83
    The problem with that is that I have several chucks. 4" , 8", three jaw, four jaw, collect etc and each one has a different size chuck wrench.
Draft saved Draft deleted
Share This Page
