GWRdriver
Senior Member
- Jan 22, 2009
- 721
- 109
This is in response to a couple of posters in Brian's ongoing Corliss build. This is a suggestion for one way to do it. My disclaimer is that although I've used all these techniques at one time or another, including pressing on an outer rim, I've never used them all on the same flywheel, preferring a casting.
The quick synopsis - the outside spoke ends will be covered by the main rim.
First, assume that what you are building is the "casting," to be finished all over by various means.
Turn the hub from the material you've chosen, and leave machining allowance in the bore. Finish turn the external surfaces. Index and drill the hub rather deeply for spoke spigots.
Make the spokes and turn a spigot at each end, long'ish spigot at the hub, short spigot at the rim.
Turn a ring (NOT the final outside rim) for a spine or sub-rim, finished on all but the outside (OD.) Index and drill this ring through for the spoke spigots. Split the ring (using a very fine saw) between one pair of spokes.
Assembled the spokes into the hub and expand the ring to allow it to snap over the spike outside ends. When completely assembled wire the split together and solder the whole. As this assembly won't be exposed to heat, and because it has sufficient strength to take whatever stresses, soft solder could certainly be used instead of silver solder. If you use silver solder, meticulously clean the parts of any oil or fingerprints and flux as you go.
Treat this assembly as the flywheel casting and clean it up (filing, dressing, etc) as you would a casting and prime paint.
Chuck the casting up and finished the OD and sides of the sub-rim.
Turn the ID of the (separate) main outside rim to a light press fit over the inner rim and press this home. Heat expanding the outside rim should allow a drop-on fit, but make sure to support it so as to align it squarely. A weensy step in the rim ID will also work.
Chuck the entire assembly and machine as necessary as if it were one casting.
Here's an example of what can be done in building up a wheel . . .
This is a flywheel for the Sanderson 1" Beam Engine, 9-5/8" diam, with 1-piece rim. The trick to this one was, first, to cobble up an attachment to counter-drill the spoke spigot holes in the rim, and as for the hub ends, the hub was split. This is not my work, it was built by a fellow in London UK.
